11 members (Bob Fletcher, quinten, gunner, Magnetoman, Richrd, henryanthony, Gordon Gray, Rex, Boomer, Wilfred, D.Bachtel),
28
guests, and
13
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,296
Posts772,448
Members12,157
Most Online151 May 8th, 2022
Posts: 1,694 Likes: 26
Crew Chief
Crew Chief
Posts: 1,694 Likes: 26 |
https://nortonrally.com/ 11 thru 15 July busy, busy , busy prepping for the rally. As of yesterday the $10 discount rally fee is over and will be $75 now + lodging or camping fee. I'll be doing tech sessions. morning, lunch break, then afternoon session for all 5 days 11-15 July. If any one has questions for discussion topics please PM or email me. Subject will be all NHT model 7 through Commando electric start. Prep maintenance on my combat. side stand mount repair/replacement, centerstand bushing upgrade to 06-4057, 850 style. I'm going to try a SS exhaust after 30+ years on my Armour roadster stainless system. This is the bike hanging on my engine hoist I was in the middle of drilling the cradle for the 850 type centerstand bushings. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16425/filename/DSCF0040.JPG) Shown is the flip and invert between the engine hoist and the Kubota forks ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16426/filename/DSCF0043.JPG) Now flipped and reattached, inverted position for broken side stand mount removal and replacement. The engine hoist lets me roll it into the shop for TIG welding. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16427/filename/DSCF0044.JPG)
Crew Chief
Crew Chief
Here is a 71 frame in need of an upgrade, and my practice piece before my combat repair. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16452/filename/063049frt.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16453/filename/063049rear.jpg) Below is the upgraded 71 frame. and on the ground the 18 degree fixture and the spare new mount for my combat. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16454/filename/71upgraded.jpg)
Crew Chief
Crew Chief
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16465/filename/23-06-2022assy.jpg) Good and productive day. 1. side stand mount repair accomplished and done. WESTLY bleach white then ARMORALL the tires.  2. install SS exhaust mounts. 3.clean polish rear wheel cover. 4.Smack down speedo drive on press to remove any "bowing" (don't want any drag on buffed cover.) 5. Fill/flood speedo with 70W synthetic gear lube 5. Mount wheel into drum typical cush drive rubber needed a few attempts (3 Molson ICE not helping) 7. Install my custom top gearbox oversize bolt. 13/16 socket 8. Connect chain and saftey wire the master link and clip 9. run speedo drive cable so it routes with the "flow" 10 beer break and computer hack... 11. Sun going down, will resume 4-5 AM in the morning. Would like to have it running by end of day tomorrow 24 June will report any impediments.... After all it ran fine when parked, carbs will of course need cleaning....(E10)
Posts: 160 Likes: 8
Posts: 160 Likes: 8 |
Never mind the Norton, tell us about the Lotus!
Ian
1965 T120R 1968 T100C 1968 T120R 1973 T150V 1974 Rickman CR A75
Crew Chief
Crew Chief
Never mind the Norton, tell us about the Lotus! Ian 67 Elan S3 SE air flow Coupe, assembling my steel inventory to fabricate a rotisserie to do body repairs. 1. A little around the front grill area. 2 The trunk floor is a mess. also dynodave on https://lotuselan.net/Combat: front end and wheel going back on this morning then engine going back in. Hope it's running today....
Crew Chief
Crew Chief
Lots of chores to get this ready for the rally. Not running yet but darn close. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16504/filename/202206SS.jpg)
Crew Chief
Crew Chief
"Lots" of little jobs to clean up. It did start on the first kick. Lots of smoke from the diesel I soaked the bores with. 40+ psi oil on the gauge.Left carb still needs work as it is not responding to the screwdriver tweeks. Smoke has cleared but the carb will come off for a rework. Put the center stand on. A bit of a "PULL"  to engage the center stand spring. Works fine,,,first time for center stand since 1987.Last time on road was 2019. Iron out the remaining wrinkles and go for an inspection sticker.  No one going to the NY/INOA rally 11July? Is no one curious for tech talk? Give me topics & questions for tech talk at the rally PM or email garden gate/feartherbed/ Commando 500-600-650-750-850?
Posts: 3 Likes: 1
Novice poster
Novice poster
Posts: 3 Likes: 1 |
Hey Dave, How does the muffler mount on the SS version…any mods to the frame needed? Not able to make the rally this year but you should go over the clutch and what effects on the Atlas arm installed instead of Commando arm… I was amazed at the difference. Just for us old folks with Arthritis Rod
Crew Chief
Crew Chief
Finally got it running and it was just way out idle and mix screws on both carbs Rod Same 2 bobbin diamond shape plate to muffler. Strap from shock mount stud drops down to back of top and bottom bobbin, Second strap also attaches on bottom bobbin and goes forward to top rear Z plate bolt. Easy and all you need is the pair of pipes. Heat shields also highly recommended. Can't remember if I have the Commando or atlas release cam in this combat gearbox, but is is an easy 2 finger clutch. I did drag race it many years ago @ New England Dragway. Not all that impressive with a 21t sprocket and I weighed 35 lbs more back then. Time for the 1/4 was not great but I'd come in just under 100mph in third. If I tried to shift to 4th (almost at the line) ET went up and MPH went down...
