Photos on private message
JubeePrince
JubeePrince
Maryland, USA
reverb 74
Allan G 53
kevin 53
Cyborg 30
Mark Sharp, Ian Scotland UK, cherbini, grahamsmythe, Joe Santelik
12,157 Registered Users
12 members (bill50cal, pigpen, L.A.B., quinten, Bob Fletcher, triton thrasher, reverb, gunner, Magnetoman, Richrd, henryanthony, Gordon Gray), 28 guests, and 14 robots.
Topics76,296
Posts772,448
Members12,157
Most Online151
May 8th, 2022
#883224 06/18/22 5:34 am
Rohan Offline OP
Anyone have a sample of genuine circa 1949 wiring to show ?
Mine was well past its best by then. Very well past it.
Anyone explored the quality of the wiring harness supplied in
the spiffy new Lucas red (or green) boxes ?
AJS & Matchless on eBay
Rohan #883343 06/19/22 10:51 pm
Rohan Offline OP
I've already had a reply, elsewhere. Thanks Lex.
"Never ever use the ready made ones, totally wrong construction and materials, and way too expensive.
By 1949 rubber covered wire was still used, have had several NOS lamps with looms attached to them."
I suspect this sums up the situation 100%.
More on this shortly.
Rohan #883350 06/19/22 11:55 pm
Rohan Offline OP
The wiring chart that came with this kit was a little strange.
And remarkably short on detail.
When I hauled it out of the box, thats exactly what the main loom looked like though !
A mix of bare wires, braided over wires and wiring in a plastic tube.
The headlamp is on the left, and the middle of the bike on the right.
The large handful of smaller looms and chunks of extra wire hinted that this was going to be a challenge,
And not entirely straightforward - the colour coding was nothing like diagrams I've seen for this year/model either ...
It does mention down the bottom to refer to the diagram for your bike ...
Rohan #883370 06/20/22 6:30 am
Rohan Offline OP
Hmmm, all these extra bits and more harness came in the package too.
Not impossible to figure out, although the yellow/green wire pair are a bit of a mystery at this stage.
No explanation or instructions for these.
It does say to refer to an original harness diagram (which you have to locate for yourself)
I'd comment also that the original harness was all black rubber coated wire, with little colour coded ends.
So coloured plastic wires are not entirely an exact replacement !
Rohan #883493 06/21/22 10:56 pm
The yellow/green pair connect the generator to the regulator.
Rohan #883497 06/21/22 11:16 pm
Rohan Offline OP
Thanks Trev.
Where do you get that from ?
Now, this harness has quite a number of bullet connectors on it.
As far as I am aware, a 1949 bike would have had zero * bullet connectors ?
There is nowhere - and no provision - to plug them into anywhere or anything ..
The harness for 1949 would have been all black rubber coated wires.
With coloured bands at the ends to identify them.
* With the possible exception of the connectors into the generator.
These had a pre-bullet type of connector - the wires were splayed out over a tin collar.
Rohan #883602 06/22/22 11:05 pm
Rohan Offline OP
Remains of the 'wiring' on a similar era project I have.
Miller, not Lucas though.
Any coloured wire you like - as long as it is black. !
Note how many (tinned) strands are in each wire.
Quite generous - and essential for 6v ...
If you look closely, one strand is/was actually red rubber.
P.S. Someone has contacted me with a nice sample of an original Matchy wiring harness.
All black rubber coated wiring, as you would expect.
Not sure if I can show his pic ...
Rohan #883603 06/22/22 11:14 pm
The yellow/green wiring for the generator is standard Lucas. Check out the wiring diagrams for other makes. The connections on the generator and regulator are known as split sleeves.
I had a look at a 1949 wiring diagram and it shows the wires as being coloured.
I had the unenviable task of sorting the wiring on a plunger A10 which had one of these horrible repo harnesses fitted. Very few of the wires matched any wiring diagram.
Rohan #883604 06/22/22 11:17 pm
Rohan #883607 06/22/22 11:46 pm
Rohan Offline OP
Ha !
I had a look at my dominator wiring diagram, and it indeed shows those colours.
The old grey cells must be fading ...
The rijjinal harness pic that someone sent me has coloured bands on the very ends of
an all black rubber coated wiring set.
I have some little shrink wrap bands that I use for the same purpose.
I doubt these were available back then, I wonder how they did it ?
P.S. And if you haven't twigged, then Dim is parklights.
Same as L in the Lucas world ...
Moderated by  Matchman62
