8 members (henryanthony, Magnetoman, Lannis, htown70, reverb, Doug P, The Momes of Wrath, steelheadchaser),
7
guests, and
21
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,552
Posts776,412
Members12,212
Most Online204 Jul 10th, 2022
Posts: 4,056 Likes: 62
Posts: 4,056 Likes: 62 |
Hello; any of you with a 9989 camshaft (Harris made) on the bench can tell me if the hole threads in the TS are UNF or BSF? Thanks
Posts: 1,524 Likes: 51
Parts Dealer
Parts Dealer
Posts: 1,524 Likes: 51 |
Posts: 674 Likes: 74
Posts: 674 Likes: 74 |
20 tpi, same as bsc? I know that the earlier nut fits, as does the factory assembly tool.
Hi TinkererToo; the hole is for 1/4 so if it is UNF should be 28tpi. Seems that you are talking about the external thread.
Sorry, I was, can you get a 1/4 UNF tap in Uruguay?
Hi; I dismantled there to be sure what I did in the past and found the screw a bit loose but UNF. I tested a BSF but did not worked. Would be very very frustrating tear up the cases to fix that but seems that I did the testing when I built that. Yes; there are UNF taps here.
Just run a tap up the hole, it goes no-where else, so no need to dismantle!
I removed the magneto to check that but I do not think that an UNF tap into a BSF thread can make for a good tight hold for the taper of the magneto to the camshaft; anyway was UNF and had the UNF bolt there so was all good.
