by C.B.S - 09/22/22 5:28 pm
Tridentman
Tridentman
kevin 115
DavidP 60
kevin 30
reverb 29
12,261 Registered Users
10 members (tridentt150v, quinten, Stuart Kirk, NickL, charlie akey, R Moulding, Mitch, GrandPaul, desco, Doug P), 13 guests, and 25 robots.
Topics76,325
Posts777,860
Members12,261
Most Online204
Jul 10th, 2022
#883548 06/22/22 2:52 pm
reverb Offline OP
Hello; any of you with a 9989 camshaft (Harris made) on the bench can tell me if the hole threads in the TS are UNF or BSF?
Triumphs on eBay
Parts Dealer
Parts Dealer
reverb Offline OP
Thank you mate.
20 tpi, same as bsc? I know that the earlier nut fits, as does the factory assembly tool.
reverb Offline OP
Hi TinkererToo; the hole is for 1/4 so if it is UNF should be 28tpi. Seems that you are talking about the external thread.
Sorry, I was, can you get a 1/4 UNF tap in Uruguay?
reverb Offline OP
Hi; I dismantled there to be sure what I did in the past and found the screw a bit loose but UNF. I tested a BSF but did not worked. Would be very very frustrating tear up the cases to fix that but seems that I did the testing when I built that.
Yes; there are UNF taps here.
Just run a tap up the hole, it goes no-where else, so no need to dismantle!
reverb Offline OP
I removed the magneto to check that but I do not think that an UNF tap into a BSF thread can make for a good tight hold for the taper of the magneto to the camshaft; anyway was UNF and had the UNF bolt there so was all good.
