Photos on private message
Les P
Les P
reverb 74
Allan G 53
kevin 53
Cyborg 29
Mark Sharp, Ian Scotland UK, cherbini, grahamsmythe, Joe Santelik
12,157 Registered Users
8 members (R Moulding, Falcon_52, Doug P, Cyborg, slow learner, Brian Brown, L.A.B., JonnyD), 37 guests, and 17 robots.
Topics76,296
Posts772,439
Members12,157
Most Online151
May 8th, 2022
#883259 06/18/22 7:07 pm
DAMadd Offline OP
Getting ready to put the head on the t150. Going by the parts and service manuals there should be 4 studs, 8 pillar bolts there's 9 pillar bolts, no studs. But seemingly no bolts the right size with the 3/8 thread. Do people just replace the studs with pillar bolts or just straight up 3/8 threaded head bolts??
9 isn't good admittedly I collected up the bolts on a cart next to the bike and maybe the PO had some on order or was planning to order. Any sage advice about where to get a head bolt set? Baxter cycle listed a t160 set as out of stock and the internet is yielding tons of t140 sets
65 TR6R 68A65T 69 B44VS. 74 T150V 19 Chieftain
DAMadd Offline OP
Addendum: found a barrel with 4 studs and all pillar bolts on the mockup motor on the weird Rickman. So now the question is: use the studs with nuts (stock) or use 4 of the pillar bolts with shorter bolts as I assume the PO was going to?
Currently soaking the studs/pillar bolts of the extra barrel in wd40 probably get some penetrating oil and soak em for a few days longer before attempting removal (+heat)
DAMadd Offline OP
Just realized they're 5/16 24 grade 5 bolts. Not hard to find at all
Now just have to figure out stud vs pillar bolts
Stock bike? Had 4 studs in the outer corners and pillar bolts elsewhere. North frames typically used pillars all around. Two bolts had a threaded section above the hex for the head steady.
I would use grade 8.
DAMadd Offline OP
Thanks!, Stock frame, but studs are gone (but I can replace them with the ones from the extra barrel or pillar bolts). Have the head steady bolts the rest are a mishmosh of different sizes. I'll track down some grade 8's so the rest are uniform at least. Any word on those elephant foot adjusters?
DAMadd Offline OP
Also if anyone bothers to read a boring bolt thread, what's with the thick washers? I thought I saw a thread somewhere with an explanation and po has a mass of different washers lock washers and what I take to be the original thick washer/spacer on the head bolts
The parts book is not much help, so I had a look at my head. Of course, the washers on the studs are larger diameter, but they all appear to be the same thickness. I measure the ones on the studs to be about 0.08" thick installed.
DAMadd Offline OP
Yeah, the parts book has numbers but these are like an 1/8 inch thick and the bolts that don't have them have like 2 washers and a lock washer. Gonna hit a few vendor websites to see if the parts pics match anything I have.
Was at the Nutty co. (Local bolt vendor ) getting a bunch of the other head/ rocker bolts as described above, they had thick stainless washers that are close to the few thick washers so I grabbed those too
My washers are 50 years old and measured under tension. They might have been 1/8" thick when new?
The '72 parts book gives 0.078" thick for the 1/4" rockerbox bolts, 0.094" thick for the 5/16" bolts and 0.092" thick for the outer four 3/8" studs.
DAMadd Offline OP
74 book only lists the size of the1/4". Thanks. The ones that look most stock are 0.110 which is close for the 5/16 the rest are all over the place. Going to find some SS ones and get them all to a uniform thickness on the belt sander in the area of the 0.092-0.094 range. Probably not a big deal as the guy had 2 washers and a lock washer on some, but it'll make my brain feel better. Emailed you about the elephant foot adjusters to email I found in an thread about them. Thanks again
Moderated by  Tridentman
