Hi
As Kommando said, the rings are likely still bedding in. Leave things alone until you're sure the engine is fully bedding in before doing anything.
When you say
SRM rebuilt the engine, you didn't say if it is still 650 or 750 with the
SRM kit? Allan was referring to the piston type
SRM sell for their 750 kits. I have used these pistons and rings with my big-bore kits and they have worked fine.
As Mark said the alternator wire grommet can be a cause a leak, once you've got it run-in, pop the primary cover and see if you can clean any oil off the wires, grommet and tube, then inject some silicone into the tube and build back and see if that changes your leak.
Should you have a 750 kit, then you will probably have had a rocker cover breather installed, I would have thought
SRM would have blanked off the timed breather when doing the rebuild, which is something I do, just to prevent it leaking oil.
My tuppence worth
