Topics76,030
Posts769,167
Members12,117
Most Online151 May 8th, 2022
Posts: 414 Likes: 2
Posts: 414 Likes: 2 |
I removed the clutch cover from the primary of my 1958 Square Four to see why I had some clutch slip. I found a lot of powdery grey stuff in the cover and coating the outer primary cover. The plates were fine and dry but, on removal of the basket, it was obvious that the back of the basket had been rubbing on the outer portion of the alloy cover and it was fine metal (aluminium) powder that I’d seen.
I read the comment on Draganfly”s website in which they mentioned this problem and it suggested I might have too short a mainshaft. However, if I grab the chainwheel I can slide it in and out (towards and away from the gearbox) by about 1/8” suggesting it is more than long enough. When pulled away from the ‘box, it appears to line up with the crankshaft sprocket better and the basket no longer rubs (if I temporarily replace the outer primary cover). I do not see that there should be a spacer or shims behind the chainwheel in the parts book - should there be? Any foreseeable problems if I do fit a spacer?
Thanks in advance.
Paul
'74 Commando - Interstate "74 Commando - Hi-Rider, possibly '65 Atlas, mostly anyway '15 R1200 GS Adv '51 Vincent Rapide '58 Ariel Square Four
Posts: 927 Likes: 328
Posts: 927 Likes: 328 |
It is probably time to have a good long look at a gearbox parts book and see what internal mainshaft shims might be missing or of the wrong size.
Posts: 414 Likes: 2
If I cannot fix the problem by fitting a 0.060" shim behind the basket, I will have to dismantle the gearbox next. Thank you, Stuart
Paul
Posts: 1,014 Likes: 183
Posts: 1,014 Likes: 183 |
Hi Paul, Is the main shaft moving with the clutch ? If so the problem should be apparent when you remove the outer gearbox cover The main shaft is located by the kickstart ratchet nut, the inner ratchet bush and the bearing in the inner cover
Is the clutch centre nut tight? There is a bronze shim 3394-36 on the shaft adaptor behind the roller race and one with a tab 3397-36 on the outside If these were missing it could allow the clutch to float about
A note on the needle bearings, those supplied by most suppliers are incorrect at 3/32in. diameter (.093) where as they need to be 0.100in. This mistake leaves the clutch with 0.014in radial movement I had some loud disagreements with the "usual" supplier about this when looking for replacement rollers, their answer was "that they will fit" At the time I had 6 original clutches to check against but they would not accept any correction or criticism
