Topics76,286
Posts772,333
Members12,156
Most Online151 May 8th, 2022
Posts: 6,151 Likes: 227
Posts: 6,151 Likes: 227 |
Posts: 4,673 Likes: 163
Posts: 4,673 Likes: 163 |
the thing is, you can use an ordinary bolt puller if you just grind the heads down on a couple of long bolts.
all you have to do is rememebr that ^^^this solution exists
Posts: 5,231 Likes: 195
Posts: 5,231 Likes: 195 |
There are dedicated race pullers. I bought a set from an auction a decade ago Very expensive piece of kit The idea shown will only work on bearings that are a very light fit & not corroded into position and are much bigger than found on a motorcycle. Most of what we use the cage will prevent they being done as it is too close to the edge of the race It also has no means of applying a clamping force to prevent the legs poping out A similar trick is used for pulling blind needle rollers out of cases using a ground down coach bolt
Bike Beesa Trevor
