Mark Brown
Mark Brown
Michigan's Thumb
quinten 69
NickL 29
quinten 28
EmmBeeDee, dresda, Templarian, doug_chambers, NRpolo
12,122 Registered Users
3 members (henryanthony, NickL, Mark Parker), 30 guests, and 14 robots.
Topics76,060
Posts769,580
Members12,122
Most Online151
May 8th, 2022
I am so excited !! I have been looking for GP carbs for my 1966 BSA Spitfire at a reasonable price for over a decade.. Shockingly this pair was on Ebay and promoted on facebook Spitfire group page so I was sure they would go for the normal price or more but I won the auction at half price so now my search is complete.
Aren't they pretty.
9 members like this: Mark Parker, Blown Income, royaloilfield, RobJP, BrizzoBrit, Jon W. Whitley, Hugh Jörgen, semprini, Gordon Gray
Originally Posted by wadeschields
Aren't they pretty.
Wade,
Good for you beerchug and they absolutely are!!
1971 BSA A65 650 - Project
Dont ya love it when a long search finally winds up.
Good onya!
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Spitfire GPs are like hens' teeth. You did well there.
In practice, of course, 932s work better, with the GPs kept for special occasions.
Aren't they pretty.
Good on ya.
Now to spend the next 10 years getting the bike to start easily and run well with them fitted eh?
Some blokes like a load of hassle................
2 members like this: Hillbilly bike, Shane in Oz
Yeah my bike does run great as it is so Im not in a hurry to change them out just yet . But at least I have them , as Shane said, for special occasions...
I ported a head for some of those. I wrote down specs somewhere the ports are/were just under 30mm with 42mm valves. It has very high gas speed. Because they are no bigger and flow better. The thing is 30mm Concentrics knock the flow as it's sensitive to disturbed air, much more so than the std head. (as in it still flows more but looses compared to a bell which flows quite a bit. And fighting to get it then lose lots on the carb sucks.) The Concentric isn't good at speed though 32s on the same little port are better, but I think smooth bore 30s wouldn't lose so much flow and be very fast. Which is particularly good probably.
That speed will draw more air and fuel and probably require smaller/leaner jets. It may help the carb work better perhaps. If the needle position and spray tube ordinarily function better with more draw on them it may improve their operation? Solving the fuel level and idle would be the next thing.
Does it not have an idle screw to set the slide height? Because if that was the case maybe a threaded rod down through the top could be set to stop the slide going right down. If the screw part is just the outer piece? The cables would be no good for doing that. A hole in the slide could do it but doesn't give easy adjustment, and transition might be weird, or not?
Great score Wade, your pictures bring back memories. I had a motor with a GP2 on it, and and at first,when not in use I plugged it with the usual bathplug. This didn't seem a good idea to me, as junk could sit in the bellmouth beside the bathplug. What I ended up with was a sort of rubber cup that was originally used to protect the cut end of a big underground electrical cable. It fitted snugly and did a much better job of protecting the carb.
A mate of mine had a MkII Spitfire that had won the very first race at one of the Sydney tracks.
1954 Norton Dominator 88 cafe - Yamaha wheels, Lyta tank ( project in progress)
1969 Triumph Bonneville
Currently 6 other non-Brit machines.
Past history includes 11 Brit and 13 non-Brit machines.
Some impressive and some just silly.
They are absolutely Mint Wade. A great find!!
All you need now is the frame bracket for the remote float bowl and seemingly impossible to find the rubber isolastic mount. The bracket Can be made with some flat bar and some patience in shaping it.
Congrats Wade, you now enter a unique cadre of enthusiastic GP carb owners. I love to run these carbs once set up they make beautiful power range that just keeps on pulling.
Setting them up according to your instructions is pertinent: The float perfect and the cables to set up the slides are the big hitter. Yes they will idle and that is all in the cables. Keep an eye on that cable adjustment because they will change and make sure they are lubed. You might have trouble finding the correct cables.
I’m planing a 64 Spitfire Hornet replica using the GP carbs and original ET ignition with 6CA points plate. Have to finish my West Coast Hornet first.
Good luck,
Richard
1 member likes this: Vincent Esposito
Good find Wade! I ran across a set a couple of years ago at a great price myself, but they are problematic in all the areas mentioned. I have a set of 30mm Concentrics that I modified and sorted years ago and they are sooo much easier to live with. That being said, the GP's look terrific on the bike and work well wide open, not so much at low throttle settings. Mine were set up by a well known BSA tuner for a race bike and have some weird parts in them (they work pretty well though) and I drilled a 3/32' hole near the base of the rear of the slides for idle air (suggested by the tuner) and it idles quite nicely at about 7-800 rpm, but here's the rub, as predicted by Mr. Parker: With the recommended no. 5 slides and the idle screws set for best tick over I have a big flat spot just off idle, if I tune to eliminate the flat spot (richer at idle) the transition is great but it loads up at idle. BTW, simply sitting on the side stand idling the left carb goes rich and the right side goes lean due to the central float, the bike has to be held perfectly vertical to adjust the idle mixture. I think the transition situation can be cured with richer slides but at a cost of nearly $100 per slide experimenting might get costly! And then you have the fuel mileage aspect, I get nearly 50 mpg with the Concentrics and have yet to achieve any better than 30 with the GP's. With the Spitfire 2 gallon U.S. tank you aren't going far! The 'Cool' factor of GP's can't be denied though, just be prepared to spend a lot of time and money getting them as "good as they can be" and still fall short of a reliable street combination. I hope to see that beast when you're done, mine is still missing a lot of it's original Spitfre bits most importantly the engine cases having been ventilated by a connecting rod by a PO long ago. Oh well, you work with what ya got! Good luck Wade, great score!!!
71 Rocket 3
72 B50 MX
66-71 A 65 Bitsa
96 Trident 900
those look brand new
they came with the matchbox?
BUY A SET OF 68-8731 CABLES FROM BAXTER CYCLE THEY ARE THE LAST ET OFFERED BY SA FOR THE MK2. THEY ARE AN IMPROVEMENT OVER THE ORIGINAL DESIGN AND THEY HELP WITH THE IDLING PROBLEM.
The Devil is in the details.
2001 Kawasaki W650
1 member likes this: wadeschields
I already had the float and I have the bracket to hang it... The guy I got the carbs from offered to clean the float to match and it came out great. I need to look at the bracket I have to see if the parts that connect are all there. I think the bolt on top of my float looks different then the pictures I have seen of others, so I might have to source that if it doesnt work.
Great info everyone thanks !!!
Funny really as loads of those carbs were around 'knocked off' at the time
a lot of blokes tried them and gave up, especially in England as the bloody
things filled up with water all the time when it rained. They were great carbs
in the day but really just for racing. Beezer abandoned them as they gave so
much grief. A pair of smooth bored concentric32's with proper bellmouths
were better and a lot less hassle.
No good in dry old Queensland then, torrential rain and canoeing to the shops one day, cyclones and helicopter rescues the next, or what ever that saying is.
What's a smooth bore 32mm look like Nick? If they made them there is a reason.
I found some numbers in a book. Std head @ .384" 109.48cfm - with a bell 112.6cfm - with std 30mm Concentric 100.92cfm - blending the lug thing on the intake of the carb like Triumph tuning book 102.7cfm. They knew that modification gave them a bit more hp. So a smooth bore GP2? 108 or something? More than 103 I guess without the needle obstruction. If you give the engine what it wants you get hp.
I cannot find where I wrote the ported 30 down but with a bell I think it's around 150cfm but it's smoking through the little port. If it was 130-140 through a GP it would be interesting, especially drivability off the bottom and through the midrange and top end. Improving the port isn't just about top end power. It can be if it's just bigger.
They basically stop making power in the top end because the air runs out or your pipes and compression are letting it down. The cam isn't a big player as it's pretty good, it will make power at high rpm if the other stuff isn't holding it back.
This is it because it had one fin needing fixing.
This is a mold from a 30mm port I tried before, probably with a std valve. But I turned it into a 34mm because they flow more. But maybe that isn't the best rout with a 654. Tom's Hornet has only 25% or so more hp and it may not be using all the air available and need pipes and compression or 750cc because a 34mm port wants a high comp 750 to have a torque peak around 5,500 in a calculator.
Rob said generally with more flow through the same carbs means it requires smaller jets and hp will be up. Why GP2s may carburate better as there is more pull on the jets/emulsion tube. If Chris's 750 required leaner jets it should be up on hp even if the stingy new dyno isn't showing it so much. But that's probably a pipe limitation as well maybe, because he's chasing a lot.
std on the left and I think it's the better '71 port. And this isn't as good as the new 30mm. It may be the key to getting GP2s really working. Pity you do not live next door Wade.
Congrats on the find, they look beautiful! Personally, i'd prefer to have them on display rather than on the road, but hey...
If the float eye bolt can't be sourced, which is very likely, you can make one like what I did here.
A locking ring tool can be made as I did here.
Awesome Gary thanks
E
E
Good for you Wade! Spitfire Ken is right about the cables. Basically it is a cable with the regular ferule at the carb end and a second ferule a few inches above that. It comes with a hollow threaded tube with a split in it and a seat for the ferule at the top. The tube is threaded into the top of the carb where the cable normally enters. You thread it up or down to raise the slide. You then use the regular cable adjuster to adjust for free play in the cable. I have them on my Spitfire. It starts easy and idles like an old Triumph with slightly worn carbs (pretty good but not perfect). As for the flat spot that DWR talks about. I had that when I originally set my carbs up with a ColorTune. Eventually, I put the ColorTune back on the shelf and adjusted the mixture by ear until I no longer had a flat spot when opening the throttle. Its a little rich and can load up in very heavy traffic with lots of idling, but runs fine normally.
Ed from NJ
1 member likes this: Gary E
AMAL didn't make them, various blokes did them , Mick Hemmings supplied the pair
i had they were actually 33 bores once machined. A lot of blokes who raced nortons used
them, hence the Mick Hemmings connection. They were very good carbs and were
eligible under the pre 72 racing rules.
https://imgur.com/a/GYvbzcX
1 member likes this: Mark Parker
Whats the difference in them? were they just "finished"?
They were fitted with the trumpets then the assembly was bored and polished
as an item. There was no step or joint and the taper was of course just a
continuation of the trumpet. The trumpets were not removable.
Snag with them was, one of mine had the progression hole blocked by the
machined material and it was a bitch to clear, doesn't really matter on a race bike
but without those holes you know what amals are like, no idle etc.
Blimey Allen that was 30+years ago now.............. I used them for a couple of seasons
then went to the weber carb.
