7 members (HughdeMann, henryanthony, Magnetoman, quinten, BeezaBryan, MrMarty51, Robert Dentico),
20
guests, and
17
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,311
Posts772,635
Members12,160
Most Online151 May 8th, 2022
Posts: 1,942 Likes: 73
Posts: 1,942 Likes: 73 |
Does anyone use the original DC regulators anymore? I have no experience at all with DC equipment, even if my first Triumph was a T110 1958. In the process of reviving a T100, a TR6 and a T110, all 1958, and while modern regulators are available I'd like to give the original equipment a go. I have Motor Cycling Electrical manual by Bernal Osborn at hand, which should help. All tips are welcome! I don't want to go through fire and water to do this though, if it becomes difficult I'll leave it and go modern. SR
Posts: 1,201 Likes: 106
Posts: 1,201 Likes: 106 |
Thank you catt, although not quite what I was looking for. I was hoping for some hands-on tips and experiences from people who run these thing on a fairly regular basis. I have two regulators and two dynamos which I'm going to try to resurrect myself. Parts are available for the dynamos, but people seem to replace their regulators with solid state items. I might do the same, but thought it would be nice to be able to brag about using the original regulators. Would make appear to be an "in the know" kind of guy, even if I'm clueless.
What are the usual regulator failure modes? They look like decent pieces of kit to me, but they're getting replaced all the time, and there must be a reason.
SR
I will be limited in my response as my regulator experience is 20 years back, and only on a couple of bikes. Failures that I had seen in old regulators included either a burned up cut out winding or regulating winding- could see the burn marks on either set of coiled wires. On the reverse side, there was a metal strip on the MCR2 version that was frequently broken on many specimens. With the cover held in place by a wire clip, this frequently was a poor fit. Also wiring internally was often sketchy condition at best- age and heat made the covering brittle. Always use a steady hand removing cover, metal cover can easily short something inside if not graceful. I have gotten a couple to work and have adjusted them- but due to their overall age and condition would not use them for a daily rider.
Search internet for 6v positive ground regulator. I had found some relevant ones used for tractors (new 15+ years ago); also investigate one's for early 60's back MG, Triumph, Austin Healey. A small enough unit and it might fit into that regulator case labelled 1958.......
If needed, I do have a few more random pics and text to add to your knowledge base that I can copy from books if you choose to learn more about operation and repair/maintenance. Cheers! Joe
Posts: 9,098 Likes: 181
Posts: 9,098 Likes: 181 |
I tried a couple of times, before I no longer saw the point.
Broken by vibration.
Posts: 3,748 Likes: 251
Posts: 3,748 Likes: 251 |
Posts: 1,008 Likes: 4
Posts: 1,008 Likes: 4 |
SR, the pre-unit BSA service sheets have all of the information that you need to set up a regulator. Look for worn and burnt contacts, there are two sets. The most common problem with these regulators is former owners who didn't know what they were doing. Occasionally you will find an open circuit shunt coil, again there are two. A quick test of the coils is to make sure that the two armatures are free to move with a gap between them and the poles and momentarily apply a voltage to the "D" & "E" terminals. 12V is OK. You should see both armatures move. The button resistor is another problem area, usually they have a high resistance or open circuit. I use the high resistance ones but replace open circuit resistors. A fiddly job but when set up properly they do a fine job.
Posts: 2,117 Likes: 350
Posts: 2,117 Likes: 350 |
http://www.wikkeltechniek.nl/image/Lucas%20pdf/11.pdfElectronic replacement that fits inside the cover is the better way to go. Trionix DR6-10P or similar.
Thanks all. What I take from this is that you can make them work, but vibrations, age and previous missuse can make them unreliable. As reliability is more important than originality, a solid state electronic device is probably the way to go for me, I still regard electrics as black magic.
SR
Electronic regulators are great but I in my crazy ways likes to make the originals work. All that I have done, and that is many, are working reliably. The mechanical regs are repairable, unlike the electronic ones.
Trev, by the time someone has posted you the mechanical unit, you have repaired and tested it, posted it back........... a new electronic one is fitted and working cheaper.
By the way, the Trionix ones can be repaired. Just never had the need to repair one.
Posts: 4,367 Likes: 27
Posts: 4,367 Likes: 27 |
I had a B31 40 years ago and when I got it the regulator was missing so I bought a copy one that was available at the time and it didn't work at all! I took it back to the bike shop and they found me a good used one and this worked well. I like the way you could see the contacts opening and closing if you took the cover off. One problem I remember from the time was that under some condition or other on contact set could become welded together although mine didn't do this.
The What I also remember even in the early 80s was that as an 18 year old on the dole I could afford to get the dynamo completely reconditioned. It went looking like it had been under the sea to looking brand new. That work seems expensive to me these days. it is also funny that as an 18 year old I wanted a B31 and not an RD250LC!
Posts: 8,688 Likes: 249
Posts: 8,688 Likes: 249 |
A lot of the new dynamo regulators can be mounted within the guts of the old Lucas voltage regulator bodies, the Mike Hutchins? DVR2 is a fantastic regulator and can be mounted as described to keep the original appearance. I like the original VR’s especially the mechanically adjustable ones where you have the two sets of windings, though the modern versions are so much better and cheaper as Nick mentioned above, if it’s a bike I intended to “use” then I wouldn’t waste my time with the mechanical type, sealed battery and DVR2 unit all the way.
Posts: 5,233 Likes: 198
Posts: 5,233 Likes: 198 |
FWIW Peter Scott did my dynamo & magneto back in 1966 I took it back because the battery was going flat He informed me I had the wrong regulator it was for the old 45 Watt short dynamo Well despite it being wrong it had worked faultlessly for 20 years. Searching for better light because I can no longer get a good globe for the 8" I desided to replace the VR for a modern one The old unit would turn on & off at night and when it did that the lights would go dim for a couple of minutes till it turned on again . The only unit I could get at the time was the Wassel one which requires rewiring of the pick ups which I did, checked & double checked it was done as per instructions. It worked fine for about 18 months then went off the planet, took 3 LED headlight globes ( at $ 50 a pop) with it before I realised the VR was the problem . So till I can take it back for another repair it is total loss power and no extended night riding. SO not a big fan of digital VR's although this one was a Wassel & I swore off Wassel products back in the 70's because most of them were trash.
Bike Beesa Trevor
The Indian MCR2 copies are mostly hard to adjust as the adjusting screws have too coarse a thread. There were some getting about years ago with the correct threads.
I agree that the wassel units are crap, seen several dead ones myself. Probably made for less than $5. Like most electronic gear on old bikes, the margins are huge because the market is small.
The Indian MCR2 copies are mostly hard to adjust as the adjusting screws have too coarse a thread. There were some getting about years ago with the correct threads. When Peter adjusted the incorrect MCR 1 on my M20 a 1/4 turn was the difference between not generating at all and getting hot enough to melt the solder As he said to me at the time "Chances of you doing that correctly on the bike with it bouncing around ? " Yet as I said worked really well for 20 odd years, can't complain about that .
Bike Beesa Trevor
Typically the voltage control relay in one of those old MCR type units, needed to oscillate at around 50-100 Hertz to control at the 7.2v or thereabouts required. It is amazing really that they lasted as long as they did. Such crude but effective engineering. A transistor will shrug off such light duty but they need protection in other ways.
