0 members (),
21
guests, and
16
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,286
Posts772,333
Members12,156
Most Online151 May 8th, 2022
Posts: 909 Likes: 25
Posts: 909 Likes: 25 |
Hi All!
I am in the beginning stages of a teardown for a full restoration of a 1972 T120V and have noticed something peculiar with the seat latch, per the parts book and photos online, the 71/72 T120's used a clasp type latch over the previous version with the spring loaded pin type. This bike (which has been stood in a shed since 1981) is original as it gets, minus the 70's megaphones and king/ queen type seat. Question is, is there some hidden part number for the correct seat with the correct tab or maybe this was a factory oops? I have seen one other 1972 with this seat latch setup, just want to be sure so I can note if I need to fabricate a tab for the seat or not.
1955 BSA Bantam D1 Plunger 1956 BSA A10RR Street and LSR Bike 1961 BSA C15S 1966 BSA spitfire 1969 Triumph T100C 1970 Triumph TR6R 1970 Triumph TR6C 1972 BSA Lightning LSR Bike 1974 Triumph T150V
Posts: 3,639 Likes: 57
Posts: 3,639 Likes: 57 |
My 72, which is really a 72 1/2, lower seat height, has the same spring latch as you show. But my parts book shows the older style latch. Maybe the 73 parts book shows what you need.
Posts: 2,082 Likes: 31
Posts: 2,082 Likes: 31 |
Thanks A B I have printed it out. My old page was not even close. No good for the seat or the gas tank. And it only took me 35 years to notice.
Posts: 5,363 Likes: 81
Posts: 5,363 Likes: 81 |
I am in the beginning stages of a teardown for a full restoration of a 1972 T120V and have noticed something peculiar with the seat latch, per the parts book and photos online, the 71/72 T120's used a clasp type latch over the previous version with the spring loaded pin type. The low seat frame was introduced from serial number CG50414 during the 1972 production 'year' which is why the later low frame seat (and plunger etc.) isn't in the '72 parts book. The low frame seat part number is F14599 (83-4599), however, UK/General export and US version seats had covers to suit the different width fuel tanks but both had the same part number. For the 1973 model year, the seat hinges were moved to the left-hand side with the plunger knob on the right. If you were to order the 83-4786 seat listed in the '73 parts book it would be the left-hand hinged, right-hand catch seat, in the link, below. https://www.thebonnevilleshop.com/p...at-1973-77-twins-pn-83-4786-w-83-7065-w/
Blown Income |
I am in the beginning stages of a teardown for a full restoration of a 1972 T120V and have noticed something peculiar with the seat latch, per the parts book and photos online, the 71/72 T120's used a clasp type latch over the previous version with the spring loaded pin type. The low seat frame was introduced from serial number CG50414 during the 1972 production 'year' which is why the later low frame seat (and plunger etc.) isn't in the '72 parts book. The low frame seat part number is F14599 (83-4599), however, UK/General export and US version seats had covers to suit the different width fuel tanks but both had the same part number. For the 1973 model year, the seat hinges were moved to the left-hand side with the plunger knob on the right. If you were to order the 83-4786 seat listed in the '73 parts book it would be the left-hand hinged, right-hand catch seat, in the link, below. https://www.thebonnevilleshop.com/p...at-1973-77-twins-pn-83-4786-w-83-7065-w/Thanks LAB, this was my conclusion as well looking at various sites and photos that the the hinges swapped sides in 73 and I appriciate the 72 1/2 seat part number!
