Photos on private message
ricochetrider
ricochetrider
reverb 69
kevin 52
Allan G 50
Cyborg 29
Ian Scotland UK, cherbini, grahamsmythe, Joe Santelik, Lord Hepcat
12,156 Registered Users
3 members (TinkererToo, Dave Comeau, Burga007), 21 guests, and 20 robots.
Topics76,286
Posts772,333
Members12,156
Most Online151
May 8th, 2022
#878175 04/20/22 5:06 pm
reverb Offline OP
Hello; soon I will dismantle the wheel. Is it possible to achieve good results sending to polish aT140 hub? or they have kind of a "protective" coat that better let it there?
You know like the AMAL´s that is better not to polish.
By the way; polish and then spray a clear coat is not good on aluminum.
Triumphs on eBay
reverb #878181 04/20/22 5:33 pm
The 1979 and later hubs were polished and clear lacquered (instead of the previous hammered enamel 'Hammerite' finish).
reverb #878182 04/20/22 5:39 pm
Yes, it's fine to get a T140 hub polished - I've had several done and they come up beautifully, and stay looking good too, as long as you don;t let the white 'rust' start. They are made of good quality aluminium alloy, not the zinc-rich stuff carbs are made of.
reverb #878184 04/20/22 6:26 pm
Hi Reverd, Even my ‘73 is clear coated. It’s yellowing & alloy turning grey under clear.
I don’t know what they used for clear coat. It can be tough to remove. My switch consoles were clear coated & did same. I removed clear & polished off grey. They are easy to keep polished.
Salt air near ocean is hard on polished surfaces, so you’ll have to keep up on it.
Depending on how much sun it gets clear is good for about 10 years. I’ve observed the spray can do it yourself only lasts about 3 years. Lots of Sun probably less.
Personally I’d remove clear & polish.
reverb #878191 04/20/22 8:07 pm
reverb Offline OP
The clear coats only work when is done new (at the factory) if not the oxidation of old aluminum always appear under the coat.
I have the dual disc kit so I am seeing that the hub is barely seen. May be I would try to polish myself.
reverb #878199 04/20/22 9:34 pm
Paint it silver. Its not easy to keep clean when spoked up.
reverb #878207 04/20/22 10:06 pm
reverb Offline OP
Hi Gavin; I do not like paint; always chip off even more on aluminum no matter the primer. Also, I have 150 meters of a small gravel street that through mud on the rims when rain and here rains all the year, not seasons.
reverb #878218 04/20/22 10:53 pm
Gravel doesnt hit the hub, I live up a 100 m gravel drive., cleaning hubs isnt easy, when i was a kid the old guys put a loose leather band around their bicycle wheels hubs to heep them clean, looks smert.
reverb #878227 04/20/22 11:48 pm
reverb Offline OP
This gravel is more like tiny gravel with clay so plenty of mud.
I remembered those bands, that I never liked but put it on both hubs however I made it with inner tubes and did not worked. I would try with other material (I do not have long strips of leather)
These later hubs are different; you can remove both halves and do not have that big smooth surface making a bit more difficult to polish.
reverb #878254 04/21/22 10:40 am
But then you have to KEEP polishing it to maintain the shine.
That must be "fun" working around all the spokes.
reverb #878256 04/21/22 12:53 pm
I wonder who decided to give the '71 Triumphs and BSAs hubs that were close replicas of late '50s Manx Norton hubs. Bless 'em. They've been a boon for many a Featherbed-framed cafe racer - mostly on the rear, but a little ingenuity could result in a pretty fair replica Manx front wheel, too. If you don't go the 4 l.s. path.
The rear hub is a fair, but not perfect, replica. It has the great advantage of being made of aluminium, with no need to worry whether your magnesium has gone brittle.
1954 Norton Dominator 88 cafe - Yamaha wheels, Lyta tank ( project in progress)
1969 Triumph Bonneville
Currently 6 other non-Brit machines.
Past history includes 11 Brit and 13 non-Brit machines.
Some impressive and some just silly.
reverb #878257 04/21/22 12:54 pm
cant do it with a conical, but when i was a kid you could buy a leather ring about two inches in diameter that you snapped around a bicycle hub. as the whell turned the ring held back, cleanibg and polishing tbe hub interior whenever the machine was moving
reverb #878266 04/21/22 2:00 pm
H
H
Clear anodized is another option. Personally, I like the look of dull aluminum. I once polished my primary cover and when I saw what I had done, took scouring cleanser and knocked the shine back.
reverb #878271 04/21/22 2:47 pm
reverb Offline OP
Yes; there are sandwiched between the two discs so is barely seen so I will not do a mirror polish but a clean polish. I have a new rim and the spokes are Buchanan´s. Is to have a clean overall look.
Clear anodized; I never heard about that.
