Topics76,286
Posts772,333
Members12,156
Most Online151 May 8th, 2022
Posts: 322 Likes: 1
Posts: 322 Likes: 1 |
I took the footrests and rear engine plates off for paint, just to freshen things up and I found this crack/break in the corner of the left footrest. In that the material is cast, would I be able to braze this after heating, bending back and weld prepping or is it best to replace the peg...? I am actually glad that I removed the peg rubbers and discovered this...! Thanks, Rob ![[Linked Image from imagizer.imageshack.com]](https://imagizer.imageshack.com/v2/640x480q90/923/I0paj1.jpg) ![[Linked Image from imagizer.imageshack.com]](https://imagizer.imageshack.com/v2/640x480q90/922/VygfLW.jpg)
"They told me I was gonna have to work for a livin' but all I wanna do is Ride" - Jackson Browne Current: '75 T-160 Trident, '78 T-140 V Bonneville, '72, T120R Bonneville, '71 T100R Daytona, '13 Electra Glide, a garage Full of Guzzis, '88 Honda Hawk GT, '84 RZ350 KR, '78 Yamaha XS650, 1969 Dalesman Trials etc. and a '73 MGB for good measure...
Posts: 3,963 Likes: 47
Posts: 3,963 Likes: 47 |
Hello, you can weld it with cast electrodes for arc or weld with electrode for oxy acetylene. The traction strength would be between 75000-85000psi
Robert Dentico |
Posts: 4,673 Likes: 163
Posts: 4,673 Likes: 163 |
That's strange. I've straightened at least a dozen of them.
I've seen many of them bent, but never a cracked one.
They are fairly malleable, so heating them with a torch usually allows them to be straightened.
2 members like this:
Robert Dentico, Allan G |
Posts: 322 Likes: 1
Good to know. I'll go look for the stick foe Oxy.
I assume this should be heated and pulled back...?
Thanks, Rob
Posts: 2,082 Likes: 31
Posts: 2,082 Likes: 31 |
They are forged, I think? They are also fairly cheap
Allan G |
Posts: 11,644 Likes: 257
Posts: 11,644 Likes: 257 |
Malleable cast iron, first cast but then heat soaked to drive off the carbon so the carbon drops to steel levels. This means it then takes nearer the physical properties of steel than cast iron and so is bendable. So heat red hot to bend back to shape and then weld the crack. Your welder will know what stick to use on malleable cast iron, should not be far off than for steel.
triton thrasher |
Posts: 8,677 Likes: 248
Posts: 8,677 Likes: 248 |
They show up on U.S. EBAY site all the time, and at cycle flea markets (swap meets) on a regular basis also. And usually for a lot lower price than the one shown above.
Posts: 322 Likes: 1
They are fairly malleable, so heating them with a torch usually allows them to be straightened. Same here... I have not done a dozen, I recently straightened the T160 and I have straightened a couple of others but this break/separation surprised me. I'll pay a visit to a local welder to see if I should weld prep the break and pull it back or him to weld for me. I can weld but I don't want to experiment on the peg. Rob
Posts: 1,410 Likes: 36
Posts: 1,410 Likes: 36 |
I've welded them before, using an Oxy and Hytest rods, no special rods needed.
Hytest rods are copper coated looking rods and are mainly for for mild steel. Like this: https://www.ebay.com.au/itm/111522903717?hash=item19f74876a5:g:HmkAAOSwmBNhzaOI
Posts: 1,393 Likes: 26
Posts: 1,393 Likes: 26 |
They're not cast, they're forged, and usually can take quite a bit of bending & straightening. Shouldn't be any problem to weld?
Posts: 9,094 Likes: 179
Posts: 9,094 Likes: 179 |
They're not cast, they're forged, and usually can take quite a bit of bending & straightening. Shouldn't be any problem to weld? Most such Britbike rests are malleable castings.
Posts: 3,639 Likes: 57
Posts: 3,639 Likes: 57 |
I've never seen one broken but I sure have bent a few. I have a two foot long piece of pipe just for straitening footrests.
Robert Dentico |
They're not cast, they're forged, and usually can take quite a bit of bending & straightening. Shouldn't be any problem to weld? Most such Britbike rests are malleable castings. I've just looked into this - malleable cast iron is a lot more malleable, and a lot stronger, than I'd known. Quite amazing properties in fact. I've learned something today!
slofut |
In the foundry where I once worked, malleable iron castings was our primary product.
Once the new castings left the pouring room, they were placed in heat-treating ovens for 24 hours. When removed and cooled, we inspected them for flaws. A few had blow-holes that needed to be welded shut but that didn't make them any less "malleable."
Burglar-proof bases for Duncan parting meters was one such product: The die-cast meter would be mounted on top, the coins folling through a slot into the cast iron base. A round locked "door," also cast iron, gained access for the parking cop collector to the money inside.
We young guys were skeptical that the malleable iron base wouldn't crack, so our boss brought out a sledge hammer, dropped a meter base that already had a small crack on one edge on the floor, and invited us to hammer away on it.
We smashed it FLAT, yet that crack never expanded. Proof enough of malleable iron's durability for me.
Tigernuts, slofut |
Posts: 322 Likes: 1
I've never seen one broken but I sure have bent a few. I have a two foot long piece of pipe just for straitening footrests. I made a half-hearted attempt at straightening the footrest, heating the area with just a small torch, not the high heat of acetylene. Early on it was evident that the wound would not heal well, even if I could pull the gap closed accurately. Shortly after I found a good, used footrest and it arrived today. I will maybe get back to try and pull the gap closed and weld but for now it is a great paper weight. Thanks, Rob ![[Linked Image from imagizer.imageshack.com]](https://imagizer.imageshack.com/v2/640x480q90/923/CssjDP.jpg)
