chaterlea25
chaterlea25
Cork Ireland
quinten 61
DavidP 57
kevin 54
Cyborg 23
Lannis 20
12,210 Registered Users
6 members (kurt fischer, AML, Gordon Gray, jimq, edunham, gavin eisler), 19 guests, and 31 robots.
Topics76,535
Posts776,179
Members12,210
Most Online204
Jul 10th, 2022
Page 2 of 2 1 2
Originally Posted by Stuart
Harley dual output coils have no markings on the primary terminals...
... which probably reflects that, with ignition coils, doesn't really make any difference which way you connect 'em, they still produce an HT spark? wink
On an HD-type dual output coil, the secondary winding is electrically isolated from the primary winding, so it makes no difference which way the primary winding is connected, polarity speaking.
On a single output coil, one end of the secondary winding (the end NOT connected to the HT lead) is connected to one end of the primary winding. This end of the primary winding should be connected to "ground". As was stated above, the coil will still produce a spark if hooked up "backwards", but then the secondary current must go through the primary winding on its way to "ground". Since the primary winding is only in the vicinity of 3 to 5 ohms, the effect is negligible, as observed by 68 royalstar tony.
Originally Posted by kevin
it's got to be a german thing.
i used to deliver steel to a german-owned warehouse in chicago. an immense place-- 60-foot high racks of bar, angle, tube, and strap, all shapes and sizes, stored lengthwise in little cubbyholes, hole after hole, rack after rack.
the unloaders would crane the steel off my truck onto a table, and then punch a series of buttons to tell the computer where to pick up the steel, where in the warehouse to take it, and which cubbyhole to shove it into. then the automatic overhead crane would loom into view and take it away.
as i remember, the keypad was about fifteen buttons across and a dozen buttons high. all the buttons were labelled with individual and unique icons to tell the operator which button told what to the computer. but because there were so many functions, the icons were incomprehensible-- squiggles, squares, lightning bolts, zigs, zags, stars, and triangles. the symbols were all unique, but there was no ergonomic symbolism visible anywhere. couldn't tell what the buttons did.
attached to the side the keypad was a manufacturer-supplied key to the buttons in english, with words to tell the operator what crane actions corresponded to what symbol, so he could go to the keypad and punch the correct buttons.
by doing it this way, the germans had to provide each destination country with two sets of instructions-- one universal keypad with the heiroglyphics, and then a matching language-coded sign to interpret the symbols.
nobody in germany ever thought to just put the language-codes (which they had to make up anyway for each country) on the buttons themselves, and then to just skip the icons.
Ever heard of the Enigma machines?????
3 members like this: Mike Baker, kommando, JER.Hill
"if hooked up "backwards", but then the secondary current must go through the primary winding on its way to ground" - yes, however, the spark is created by the points opening so for the secondary current to make a full path it has to jump the open points or go through somewhere else, typically the battery plates where the internal resistance is an Ohm or so.
On a dual output coil with separate windings the polarity difference changes which plug is fired in reverse.
Hmm right, I was thinking electronic ignition, where the coil is always grounded. That raises an interesting question though, in the breaker points case, how does the secondary current get back to the other end of the secondary winding, even when hooked up "frontwards" (i.e., correctly), if the points are open when the spark occurs? That would imply going through the battery is normal. I know there's not much current since most of it is consumed by the spark, so I guess that's ok, but it's not intuitive (to me).
Draw it out and you'll see.
Ahh, yes German engineering like the cable operated hydraulic brake cylinder under the tank on my 76 BMW R/90 and the complicated throttle twist grip system. But they do work so......I live with them.
Page 2 of 2 1 2
Moderated by  Jon W. Whitley
