Topics76,311
Posts772,635
Members12,160
Most Online151 May 8th, 2022
Posts: 3,427 Likes: 204
Posts: 3,427 Likes: 204 |
I've taken on the task of getting a neighbors Kawasaki KLR running after a 4or 5 year sleep. I know, its not Brit but it's still s nice bike. The carb and tank are gummed up with very old gas and Marvel Mystery oil. He always ran non ethanol fuel so there is no rust, but whats in the tank is like tar and smelled like the old gas smell I remembered back in the good old days of leaded premium pump gas. I'm thinking that a good soak and rinse with dry gas (alcohol) will melt/loosen/dissolve the mung in the tank maybe? The carb is coming clean with a soak in Hydro Seal but thats not practical for the tank.
1960 BSA A10 2007 Suzuki Bandit 1957 A10 (Used to be a Triumph here) 71 Norton Commando 17 Triumph Bonneville
Posts: 471 Likes: 7
Posts: 471 Likes: 7 |
You need more gasoline. Fire with fire kinda work
Posts: 4,673 Likes: 163
Posts: 4,673 Likes: 163 |
You might try "white gas," which is what is used in Coleman lamps and camp stoves.
Available in gallon cans at sporting goods stores and some hardware stores.
Very flammable, but pure, and can act as a solvent to dissolve old car fuel gasoline.
Posts: 2,082 Likes: 31
Posts: 2,082 Likes: 31 |
Coleman fuel is Naphtha
Posts: 433 Likes: 31
Posts: 433 Likes: 31 |
Acetone and drywall screws. Shaken, not stirred.
When it looks perfectly clean, add fuel and start motor. You may find vibration has loosened even more hardened fuel and has clogged the taps. Rinse and repeat...
BobV07662 |
Posts: 364 Likes: 21
Posts: 364 Likes: 21 |
I have used lacquer thinner to dissolve coating/crap in gas tanks, sometimes with lots of old screws, shaken not stirred. When I am satisfied that the coatings, etc are gone, I treat the tank with phosporic acid, sold at Home Depot or Lowes as "Klean Strip, Phosphoric Prep and Etch", which works over the rust. Length of time depends on the amount of corrosion. When its done, l rinse with lacquer thinner, let dry, and it is ready for gas. Pretty simple, cheap, and not too difficult. Obviously, if the tank has paint you wish to save, you probably should another solvent or just hot, soapy water and air dry
Posts: 247 Likes: 7
Posts: 247 Likes: 7 |
I have user varioius pour in tank carb cleaners in the past. See what walmart has on sale.
I have used lacquer thinner to dissolve coating/crap in gas tanks, sometimes with lots of old screws, shaken not stirred. When I am satisfied that the coatings, etc are gone, I treat the tank with phosporic acid, sold at Home Depot or Lowes as "Klean Strip, Phosphoric Prep and Etch", which works over the rust. Length of time depends on the amount of corrosion. When its done, l rinse with lacquer thinner, let dry, and it is ready for gas. Pretty simple, cheap, and not too difficult. Obviously, if the tank has paint you wish to save, you probably should another solvent or just hot, soapy water and air dry Right! I use a phosphoric acid treatment that leaves a coating of zinc to prevent flash rusting. It’s a PPG product that is available from auto paint distributers. If the tank will not be used right away, I would coat the inside with clean motor oil. This can be easily rinsed out later with gas.
Posts: 247 Likes: 7
And the name of that product would be?????
And the name of that product would be????? Sorry, when I wrote my comment I didn’t feel like going out to the garage  . PPG DX520 but that was years ago. Might now be SX520. I haven’t purchased any in a while. I also use it to remove rust from small hardware bits, nuts, bolts, etc. I soak them in a glass jar. You have to monitor the process. The stuff is pretty aggressive. It makes bubbles when working. When done I screw the cap on and save it until next time. Beware of sticker shock - $35 for a quart!
And the name of that product would be????? Sorry, when I wrote my comment I didn’t feel like going out to the garage  . PPG DX520 but that was years ago. Might now be SX520. I haven’t purchased any in a while. I also use it to remove rust from small hardware bits, nuts, bolts, etc. I soak them in a glass jar. You have to monitor the process. The stuff is pretty aggressive. It makes bubbles when working. When done I screw the cap on and save it until next time. Beware of sticker shock - $35 for a quart! SEM makes a similar product called Rust Mort. I've also used Evap-O-Rust for the same thing. As a followup, I gave the tank back to the bikes owner and told him to have a go at it. He used acetone to get the sludge out then did the hand full of screws and shake trick. Worked fine.
Gordon Gray |
Posts: 5,880 Likes: 111
Posts: 5,880 Likes: 111 |
Pardon me if I'm stating the obvious, but remove the petcock(s) before cleaning the tank. I know, it's a PITA because then you have to plug the hole(s), but you don't want to destroy screen filters which may be on the petcocks.
Gordon Gray |
