All Y'all might recall that back in August last year, I'd had it with Cochise, at the Indian Riders Rally the bloody thing nearly brought on my first heart attack, trying to start it. Enough was enough, and it's not what you know it's WHO you know, as I knew him I asked the question....
Pete, says I, can you have a look at this bloody thing for me PLEASE. I'm 100% convinced it's the Carb, OK says my hero, it'll take a while, I'll come and get it....
So around September he came, rolled Cochise into the back of the van and buggered off. A couple of weeks later he called saying, you were RIGHT, the Carb is indeed a problem.....Hang on what do you mean 'A' problem...? Well there's a few other things that'll need fettling....
He then proceeded to reel off a list of little things, that all mounted up to causing a pile of trouble. And he's lovely wife said to Pete, don't you let Shaun have that back till its right, he'll only bugger it up....
Seems I don't give anyone any confidence....Some of the little things were stuff like the kickstart shaft that bolts to the back of the engine, the shaft itself was bent, due to it being broken in the past, and welded badly. This caused the teeth of the kickstart to wear away as they hit the lower frame, thus the engine wasn't being turned over properly when I kicked it. Then he found the piston rings were worn, along with the tappet lifters. Just stuff like that, everything made to make it harder to start....
Time passed and as the parts supplier over there in Germany was retiring, the parts took their time coming, the longest wait was for piston rings. We could've got them from another supplier, but Pete was adamant that the German lad was always a good parts man, so best to wait. Then finally I got the call that the bike was done, and Pete brought it back to me, but *Life* got in the way and I just couldn't take it for a spin, until today....
What an absolute JOY it is now to go through the starting procedure, turn the ignition ON and start the bike FIRST kick, so forgive me if most of the photos in my 2022 yarns contain this machine, we've got a lot of catching up to do....
![[Linked Image from i.postimg.cc]](https://i.postimg.cc/52Z9w99D/IMG-3365.jpg)
