Ok so I brought this 220 cc side valve BSA "Power Plant" engine from the 50s because the guy was just about giving it away and i believe his wife had mentioned the tip!
Well i shagged around and got it running ( very well) ...back in the day they were used a lot where there was no power access ..small saw mills , concrete mixers , water pumps. desk top fans etc
Wondering if these units were much of a thing in the USA ? They were big in rural parts of Oz and NZ
I intend getting an enormous truck alternator and an inverter to make a generator so next time there is a power cut in the street i can be the only one watching TV with ALL the lights on
It is oddly satisfying listening to it chuffing away 500-600 rpm maybe what is really satisfying is how pointless it is hahahh
any one else messed with these motors?
i will try to add some generic pics of one from the net ( never did figure the photo loading thing)
They came in 120cc, 220cc, 320cc and 420cc versions, and seem to keep on keeping on.
They used to come up here on eBay for between $40 for just an engine and $100 with something attached. I couldn't resist some of them, so have a Grazcos centrifugal pump with a 320, a reel-type lawn mower with a 120, and a couple of others, along with a couple of Hargan swing saws with M20 motors. The Mobilco swing saw with 420 stationary motor was far better than the Hargan, but so far these have eluded me.
I bought a couple of little motors in Victoria ages ago, so Trevor and I picked them up on our way to the All British Rally that year. It entertained a few people at the rally when we had it sitting there chugging away.
Jeeze, now there's something else I need. Never seen one. I could have a BSA minibike!
careful Leon !
year or so ago i started to get a few of those little 98cc Villiers 2 stroke engines come my way ....Y'all probably didnt see many of them in USA cause they were largely used on lawn mowers.... they can become addictive ... they are surprisingly well made and so dang easy to work on ...I brought some huge load of bits (and payed by the KG ) so far i have 1 runner out of the bits and another very likely to go soon as well
now i have 5 of the little MOFOS so only need another 3 and i can set up a countershaft system and build a 800cc 2 stroke V8 ... it will probably be quite fast . I can get a roiling wreck of some ricer that i wouldn't mind taking the gas torch to mount the V8 hahahah ... more like a "square 8 " or it would be too wide ...man the things we do eh
im sure the wale huggers wont mind me using it to burn my oil change oil with hhahaha it would smoke like a train ROFLMFAO
Alan Millyard has some competition. Good to see. You could start off on a smaller scale, with a V twin, W three or V (or square) four. Then reconfigure them on a regular basis to keep it interesting. How about setting the 5 out in a radial layout? The possibilities are endless.
Even 8 of the little buggers would scarcely pull the skin off a rice pudding - the porting is all wrong, and blue smokes really need to be at least square to do anything. The exhaust system would be a sight to behold, though
The first engine I ever built was a BSA 320. It used to run the spinner on a truck mounted lime spreader. I still have it 40 years later. It has some torque.
I enjoy firing it up every year or so for a trip down memory lane.
I have a spare Lucas SR1 magneto for it but I don’t think they work on bikes. I think they spin the wrong way. Not sure.
'51 C11 in a '54 C10L frame. Back on the road... '70 Triumph Trophy 500. Next on the bench for a refresh! '72 Triumph Tiger 650. Back on the road...
I think the platform-mounted SR1 on BSA industrial motors has the same shaft height and rotation as the magnetos used for B series singles. What they don't have is any advance/retard mechanism.
The story was that they were rather sought after by racers, being a rotating magnet type. That might be complete rubbish, like lots of stories Ive been told over the years.
There is a flange-mount SR1, used on Wisconsin stationary motors.
im not sure about "Even 8 of the little buggers would scarcely pull the skin off a rice pudding - the porting is all wrong, "
my thinking is that chain driven countershaft with each motor "timed" to deliver its power shot at 45 degrees so you would get 8 pulses per countershaft rev...one thing it would be is smooth . Probably just direct drive as setting up clutches gearboxes etc would be to much like hard work...probably a belt secondary drive with some informal arrangement to tension the belt as a pretend clutch
to me its all about the unGodly racket it would make plus the haze of smoke hhahaha ..road legal wont get a look in hahhaha . I recon if i can make it go at all that would be an achievement.... dont want to spend mega bucks on what is effectively a joke project ..
Not going do wreck the motors as even they are collectable ...all done in a way it could be dismantled and get back 8 little units not hacked around .
LEON : the "strangler" was only available on the BOSTON export model of the 60s since they only had one.
I'll take a guess that you have a bunch of these
It wouldn't be too difficult to make up a cradle to set out a pair of them as a V twin, with the crankshafts coupled with a belt or chain. The flywheels are rather bulky, so they would need to be spaced a bit far apart. The a V4, V6 or V8 is just a matter of adding more V twin pairs. Easy enough to do for a bit of fun.
Getting carried away, lose the flywheels and use an external flywheel and use a points/distributor/coil ignition system. Something from a Holden or Ford V8 would be the shot.
Oh, and I forgot about the option of a Big Mother Villiers flat twin configuration. There are lots of ways of configuring blocks of little two strokes.
Shane : yes similar to the one in your pic , but that one is a very early one .
you cant loose the flywheels because they carry the magnets for the ignition
im leaning towards the "double " square 4 with one bank on each ide of the countershaft
as regards V twin ...now that would be gutless
im picking that with tall final drive ratios you could hit quite a respectable straight line top speed ...the buggers like to rev ... cant make the configuration too tight as they need a lot of cooling air
That's the reason for going to externally powered ignition in Stage 2, somewhat similar to later Bantams. It's a more complex setup, but gives back quite a bit of space at the crankcases.
You could also try a double V configuration, which would be something along the lines of half a radial.
That's just a proof of concept to get the layout figured out.
I was initially thinking of a transverse layout like the Moto Guzzi V8 or Honda CBX, but the double square 4 or double V4 might work better as a longitudinal arrangement like a Moto Guzzi or BMW. The sky is the limit. How about a V12?
The really annoying thing is ever the tiny 87cc had an end fed crank Something BSA neglectrd to do an anything other than the B series singles tha have all ball & rollers so they would have been happy with splash lubrication. BSA eventually sold the stationary engine division to Villiers So the Villiers 4 strokes are BSA Power Plus engines with a slightly altered cowel. Randsome & Marles ( UK ) plain old Ransomes in the USA at some point in time boght the rights to the 98 cc & 120 cc engines and was making them branded BSA right up till the 90's fitting them to their reel mowers from 14" to 28" cut FWIW low Hp range Model B , 98 cc 54mm x 44.5mm 1.9 hp @ 3600 rpm Model C 120cc 56mm x 50mm 2.25Hp @ 3600 rpm Model D 220cc 68mm x 60mm 3.75 Hp @ 3000 rpm Note these are all over square engines and had flywheel magnetos , mainy Wipac
High Hp engines Models A & F 320cc 76.2mm x 69.8mm 5.5Hp @ 2750 rpm Models E & G 420cc 82mm x 79.4mm 6.25Hp @ 2750rpm These are as Shane descrbed with external magnetos & again over square .engine with end fed crank A & E had shallow sumps for things that don't move , generators . compressors etc. F & G have deep sumps for things like tillers that do move.
Final series Called Series 90 All 87 cc 54mm x 38mm 1.9 Hp @ 3,600 rpm Appears to be 7 or more models Depending upon PTO dimensions & orientation of mounting bolts Also one vertical shaft suggesting it was to be fitted to rotary mowers
No mention of the prior to WWII and the use of the Invictus ( horse logo ) sugests that they were a company BSA took over during or immediately post WWII . If any one asked me I would hav said the sell off was in 1958 but the series 90 catalogues is dated 1961 and mention of the previous A-G models after 1958 The earliest mention I have of them is 1940 coupled directly to a generator for recharging aircraft batteries In Kim"s lattest ( or previous) edition of the BSA literature is some of the Data sheets and most of the E series service sheets ( same as for A10's etc )
Reminds me of a project a nutcase friend of mine had on the go, he reckoned he was going to produce the 'Worlds Fastest Lister' to compete with the kiwi's.
Shane im not going to turn it into some complex engineering project ...just dont have the gear anymore ...sure V (or what ever ) 24 would be fine BUT then i would need 24 engines
i recon a double block of square 4s each side of the countershaft would be a pretty good compromise
