Topics76,777
Posts788,039
Members12,439
Most Online230 Mar 11th, 2023
Posts: 1,528 Likes: 452
Posts: 1,528 Likes: 452 |
Primary chain needs replacing, so started looking at belt drives, which took me to cNw where the belt drive is contained within the e-start assembly.
Hmm. Pricey, but what's a knee worth, right? Opinions/experiences?
What we've got he'ah... is failure... to communicate.
Posts: 6,721 Likes: 378
Posts: 6,721 Likes: 378 |
that is actually a very rational comparison.
and other stuff
Yes, it's un-natural for me, but I have to get it by the wife.
Posts: 14,924 Likes: 506
Posts: 14,924 Likes: 506 |
My MKIII is the hardest kicking bike I've ever had in my life. I wouldn't be using one without an assist!
Patriotism is supporting your country all of the time and your government when it deserves it.
Posts: 1,280 Likes: 23
Posts: 1,280 Likes: 23 |
Lannis Lannis, I have to agree: Commandos are the only bikes I've not been able to kickstart by just straddling the bike while it's sitting on the ground. That could be why so many people start them on either the center stand or side stand ... with understandable results. .. Gregg
Spyder Integrated Technologies Lucas & BTH Magneto Restoration Lucas & Miller Dynamo Restoration SMITHS Chronometric & Magnetic Instrument Restoration [email protected]
Posts: 5,115 Likes: 119
Posts: 5,115 Likes: 119 |
A sure sign yer Amals are all out of tune !
My 850 Mk2, all tuned up practically started its self - a half prod and it was running. Choking it with the chokes and choke lever was ESSENTIAL from cold, and a good tickle.
I bought a new pair of Amals to achieve this - the old worn relics it came with just couldn't reliably start. After about 6 or 7 cleans, eventually they were nearly as good as the new ones - it helps being able to compare them. The passages seem to get white corrosion in them (moisture ?) and nearly impossible to remove.
And this makes all the difference ... If the idle passages are blocked, you are trying to start it on the needle jets. This gives somewhat hairy starting and running, to say the least ... And requires a much bigger kick to get enough mixture flowing to give it something to start on. ?
P.S. A survey in an old british bike magazine concluded that ~75% of twin carb bikes coming into a workshop somewhere were not well synchronized either. Small wonder that twin carbs had bad press ??
Posts: 429 Likes: 3
Posts: 429 Likes: 3 |
Hi Hugh, My Mk 11A has always been a reliable starter - with Trispark ignition and a pair of AMAL Premiers, it only needs one or two prods. However, on the rare occasion I have stalled the bike in heavy traffic (it only seems to happen in busy traffic with trucks bearing down on you) kickstarting it has been a stressful experience. Decided I will have this bike as long as I can so invested in CNW's electric starter - and have thanked the gods ever since. It is a beautifully made kit that justifies its eye-watering price. Now a single brief prod on the starter button fires it up immediately. Paul
Paul
'74 Commando - Interstate "74 Commando - Hi-Rider, possibly '65 Atlas, mostly anyway '15 R1200 GS Adv '51 Vincent Rapide '58 Ariel Square Four
Hugh Jörgen |
my norton is a hard starter. not that it doesnt start and run immediately, but that the force to make it turn over is greater than anything else i have. its a one or two-kick start, even after sitting forever in a cold shop, and i mean months. i attribute the shorai battery for that. but its hard to physically push that lever over. dunno what the compression ratio is. the last guy took out the suicide side-cut pistons (its a 1970) and put in different ones, but i dont know what they were.
and other stuff
Posts: 11,813 Likes: 317
Posts: 11,813 Likes: 317 |
Mine is a 2 kick starter, but the kicks need to be strong as the gearing kickstart to crank is tall.
Howard Inough |
Posts: 594 Likes: 87
Posts: 594 Likes: 87 |
First kick cold. 1 or 2 warm.
1974 Norton Commando 850 1975 Yamaha DT400B 1984 Yamaha RZ350 2007 Triumph Tiger 1050 2014 Triumph Rocket III 2021 Yamaha Tenere' 700
Prepping for e-start install. Might as well refresh any exposed seals etc while I'm in there. Have new 04-0132 seal (a metal faced one) and 04-0131 spacer. I'm working on the assumption these 2 can be pried or picked from the bore without disturbing the sleeve gear. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/14767/filename/sleeve_gear.jpg) Stop me before I get in there with the ice pick.
Posts: 5,581 Likes: 108
Posts: 5,581 Likes: 108 |
I'm working on the assumption these 2 can be pried or picked from the bore without disturbing the sleeve gear. Yes.
Good-o. I shall press on. Thanks L.A.B.
If the seal does not come out with prying then screw in some self tappers and pull with pliers.
So seal first? My initial thought was making a couple of short ended hooks and sliding them up the spline grooves at 12 and 6 then pull. Get the spacer clear then seal should be simpler?
Spacer first I would have said as it should just slide out.
Bent some picture hangers Fabricated 2 special tools to slide up the grooves and pulled out the spacer. Then a couple hook picks behind the seal and Bob's yer Uncle. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/14771/filename/hooks.jpg)
pushrod tom |
Am I doing a King Canute impression thinking I can effectively seal the output side of the gearbox? There was some yellow crud adhered to the sleeve shaft threads, some kind of plumbers putty thread locker I think, not a sealant. As mentioned previously, I have a new metal faced 04-0132 sleeve gear oil seal and spacer. The use of an O-ring on the main shaft between the clutch washer and gear face was mentioned: Sleeve gear O-ringIs a radius of RTV around the bore that the 04-0132 fits into a waste of time? From what I gather the most likely cause is weeping past the sleeve/main bushing.
Thanks for that, worked a treat.
Bruno's barrels get hosed prior to head removal. Covers were all off so borrowed the wife's shower cap. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/14987/filename/20220303_140338.jpg)
Posts: 576 Likes: 69
Posts: 576 Likes: 69 |
Bruno's head gets hosed prior to removal. Covers were all off so borrowed the wife's shower cap. She wasn't home, I take it?
Hugh Jörgen |
