Photos on private message
Morgan aka admin
Morgan aka admin
Sävedalen, Sweden
reverb 88
Allan G 56
kevin 50
Cyborg 33
Jim Harris, Cuppy, budpotter, Mark Sharp, Ian Scotland UK
12,160 Registered Users
9 members (Gordon Gray, desco, Rob Smith, JubeePrince, Noe, Magnetoman, Steve Erickson, bsalloyd, StephenM), 22 guests, and 13 robots.
Topics76,310
Posts772,624
Members12,160
Most Online151
May 8th, 2022
#869835 01/22/22 8:48 pm
I recently purchased some new rubber Gauge rings for my 66 Lightning and was wondering if anyone has any tips for installation....getting them out was a pain!
Should I put the rubbers on the cups first or put gauges In the cups in then install the rings...really stiff.
66 Lightning
73 Commando
22 Bonneville T-120 green Goldline
Rubbers on cups. Put some kind of rubber lube on ring and push instrument straight in. Sometimes a bit of heat from hair dryer might help.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Thanks for advice Beach! 👍
66 Lightning
73 Commando
The first ones I purchased off eBay were so stiff that they would have been impossible to use. I ordered some from a reputable supplier and while they were still difficult they actually worked.
The Devil is in the details.
2001 Kawasaki W650
2001 Kawasaki W650
You can always warm them up with the heat gun before installing them. Then some rubber lube to help them slide into place. Those rubbers really can be a pig. They were too stiff from new and caused instruments to have an early lifespan. Hence why they used the full rubber cups later on.
But I have reused original rubber mounts that have hardened with a bit of warmth and some Vaseline.
in time they will develop a split or 2 around the top edge, ok it doesnt look flash but leave them unless they are real bad, makes getting speedo/tacho out way easier ..
..if you want a pig try the A10 narcel one ....damm near impossible to get the speedo sitting straight
Thanks for all the reply’s. The ones I bought were a cheaper aftermarket set that were not the best , but after lots of heat and fluid manipulation I managed to get them together...what a pain!
Thanks again.
Nate.
66 Lightning
73 Commando
I use P-80 Emulation on all rubber installations. It may seem expensive but once you use it you’ll never go back to anything else.
Parts Dealer
Parts Dealer
I found the new ones on the market to be a problem, one of the reasons why we stopped stocking them years ago
Someone was selling NOS rubbers on eBay, much easier fit over the gauges and onto the cup
