Topics76,777
Posts788,039
Members12,439
Most Online230 Mar 11th, 2023
Posts: 195 Likes: 40
Posts: 195 Likes: 40 |
Does anyone know a source for the plug for the accessory socket on a 1975 Commando 850 Mk3? I know there are complete packages of plug and receptacles for sale, but all I need is a plug. This would be very convenient to use with a battery minder.
Current Bike: 1968 Triumph Bonneville T120R, 1969 BSA Victor Special, 1975 Norton 850 Commando John Player, M1030M1 U.S.M.C. Diesel Previous British Bikes: 1968 BSA Lightning, 1969 BSA Lightning, 1969 BSA Firebird Scrambler, 1972 BSA B50 Gold Star, 1974 Triumph Trident Previous Non-British Bikes: 1983 BMW R80RT
Posts: 5,581 Likes: 108
Posts: 5,581 Likes: 108 |
I found a complete NOS plug and socket on Ebay for a total of $26.15. I intend to use the plug to maintain the battery with a NOCO charger when needed.
Posts: 5,115 Likes: 119
Posts: 5,115 Likes: 119 |
How do you go charging the battery with original electrics on the bike ? Wouldn't the zener diodes be doing battle with the battery charger ?? I've always disconnected one terminal of the battery on about everything I've owned to do any charging. That smoke is expensive to replace ... ![[Linked Image from orarc.org]](https://www.orarc.org/wp-content/uploads/2017/04/wire-harness-smoke-Custom.jpg)
Posts: 1,787 Likes: 43
Crew Chief
Crew Chief
Posts: 1,787 Likes: 43 |
How do you go charging the battery with original electrics on the bike ? Wouldn't the zener diodes be doing battle with the battery charger ?? I've always disconnected one terminal of the battery on about everything I've owned to do any charging. SNIP[/img] This is correct. though the 14.3 voltage level is slighty higher on a MKIII when your charger will start cooking the twin zeners. ![[Linked Image from atlanticgreen.com]](https://atlanticgreen.com/images/zener.gif)
Posts: 11,813 Likes: 317
Posts: 11,813 Likes: 317 |
You can find these connectors easier by looking for Land Rover parts, they were fitted to Land Rovers before Commando's.
Posts: 1,280 Likes: 23
Posts: 1,280 Likes: 23 |
Gary, You can get new plugs and sockets of this kind from Walridge Motors in Canada ( www.walridge.com). Part number i s 06-2666., and their current price is around $22.95Cdn .. Gregg
Spyder Integrated Technologies Lucas & BTH Magneto Restoration Lucas & Miller Dynamo Restoration SMITHS Chronometric & Magnetic Instrument Restoration [email protected]
Crew Chief
Crew Chief
If you want an accessory plug than great, however if your charger like mine goes to 14.8 sometimes, than it will never go to "hold mode" because the zener does not go higher in impedance like a battery would.
The two Mk3 Zeners are connected to the AC side of the charging circuit. With my battery charger connected, the meter reads 15+ across the battery, 0 volts/amps at the Zeners, both of which are stone-cold after many minutes.
I'm not familiar with Norton Commandos prior to the Mk3. The Riders manual for the Mk3 specifically states that you can use the power point to hook up a battery charger or maintainer without having to disconnect anything. This is a very handy feature. The plug is also polarized so you can't plug it in backwards.
Crew Chief
Crew Chief
Yes the MKIII is a bit different. Les may need to have his meter calibrated as +15 is over the top as what is normaly expected at the battery but not above the zeners ability to dump excess power (the main issue) +15 V at the battery requires 15.6V to the accessory port!, battery charger on nitrous? My Sears DieHard and Deltran battery tender I don't think don't go that high...but do just keep cooking away.....and eventually go to storage mode. I would still prefer (and do) pull the fuse and hook direct.on the battery. " 0 volts/amps at the Zeners" ?
Crew Chief
Crew Chief
In the final result your bike will probably still start on a slightly less charged battery and.... not kill your charger. Better charge if direct on battery? I think so !
Les may need to have his meter calibrated as +15 is over the top as what is normaly expected at the battery but not above the zeners ability to dump excess power (the main issue) +15 V at the battery requires 15.6V to the accessory port!, Battery charger on nitrous? My Sears DieHard and Deltran battery tender I don't think don't go that high...but do just keep cooking away.....and eventually go to storage mode. That was with my battery charger on the 'High charge' setting and eventually dropped back to 0 Amps. My point is there were 0 Volts at the Zeners. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/2yZF2mMm/CommandoMk3ChargingCircuit.jpg)
I just discovered that my NOCO smart charger will not charge the battery in my Mk3 through the accessory port. However, when I hook up a 30 year-old charger to the accessory port, it charges the battery fine. When I remove the fuse, the NOCO smart charger will charge the battery. With the fuse installed and the NOCO smart charger hooked up to the accessory port I measured the voltage at the accessory port. The voltage cycles between 12.3 - 12.7 every second or so for about 15 - 20 minutes when the charger shuts down. I repeated the test with a second NOCO smart charger and again with an Odyssey- brand smart charger with exactly the same results. Something is obviously happening with the zener diodes that is impacting smart chargers. When I measure the voltage at the accessory port without any charger hooked up, I measure exactly 12.0 volts. Obviously, all tests with engine off.
Crew Chief
Crew Chief
Do you have the 5K uF blue cap? Pull the - neg lead off and see what happens when you try again? Zeners have a instantaneous response but the cap is like a slow filling air tank,,,,,its could be a mismatch of the the " time response" of the charger circuit.
I just discovered that my NOCO smart charger will not charge the battery in my Mk3 through the accessory port. Maybe try with the 2MC (blue can on a spring near the battery) disconnected? Edit: Dave posted as I was typing.
Posts: 4,081 Likes: 351
Posts: 4,081 Likes: 351 |
where are the zeners , on the Z brackets ? should be easy to feel some heat from them ... if the charger is forcing them open
where are the zeners , on the Z brackets ? Yes. should be easy to feel some heat from them ... if the charger is forcing them open ...The Zeners can be disconnected as the terminals of both are accessible and see if that changes anything.
seems to me you could put/leave the 2 zeners , on the ac side , but behind a full bridge rectifier . ( not the half bridge as originally supplied) this would add a bocking diode in front of each zener when charger voltage is seen from the battery side . .
I finally received my new plug for the accessory receptacle. The receptacle on my Mk3 is wired such that the rear contact is positive and the front contact is negative. The plug I received is wired so that the terminal that goes into the rear contact on the receptacle is the brown lead. The red lead contact goes into the front contact on the receptacle. The plug is polarized so that it can only be inserted one way. The Mk3 electrical system with positive ground uses red insulation on the positive or ground wires as you would expect. On the plug, it is reversed with brown being positive and the red lead negative. The plug is obviously an original Norton part as it is packaged in Norton packaging with the correct Norton part number. Does anyone else have an original Mk3 accessory plug and if so, how is it wired? I will need to remember that with my plug, brown is positive and red is negative. I thought about rewiring the plug, but I think I would destroy the plug if I tried.
I appreciate the help. I didn't look at the plug that closely. The pins on mine do unscrew so I can swap the wires around. My plug came with wires. I'll swap the wires so that red is positive before someone hooks up a battery charger with crossed polarity. I' also going to hook up a pigtail that matches my NOCO charger like I have already on my other bikes. The NOS plug and receptacle I bought has obviously been around a while. It has a price of $6.00 USD on the package!
The plug is also polarized so you can't plug it in backwards. Yes the plug will not fit backwards but current will flow if the accessory on the other end is on when the pins touch the wrong sockets, so plug in correctly first and then turn the charger or accessory on.
