Topics76,535
Posts776,179
Members12,210
Most Online204 Jul 10th, 2022
Posts: 41 Likes: 4
Posts: 41 Likes: 4 |
I recently purchased some new rubber Gauge rings for my 66 Lightning and was wondering if anyone has any tips for installation....getting them out was a pain!
Should I put the rubbers on the cups first or put gauges In the cups in then install the rings...really stiff.
66 Lightning 73 Commando 22 Bonneville T-120 green Goldline
Posts: 1,113 Likes: 90
Posts: 1,113 Likes: 90 |
Rubbers on cups. Put some kind of rubber lube on ring and push instrument straight in. Sometimes a bit of heat from hair dryer might help.
Bill 1974 Norton Commando 1966 Lightning 1965 Lightning Rocket 1966 Norton Atlas 1967 Norton Atlas 1948 Panhead
Allan G |
Posts: 41 Likes: 4
Thanks for advice Beach! 👍
Posts: 372 Likes: 10
Posts: 372 Likes: 10 |
The first ones I purchased off eBay were so stiff that they would have been impossible to use. I ordered some from a reputable supplier and while they were still difficult they actually worked.
The Devil is in the details.
1957 BSA A10 Spitfire Scrambler (numbers matching, very correct, very nice condition) 1965 BSA A65 Lightning Rocket "Clubman" (restored) 1966 BSA A65 Spitfire MK-II (restored) 1967 BSA A65 West Coast Hornet (under restoration) 1975 Norton Commando Roadster (2100 miles) 2001 Kawasaki W650
Posts: 8,756 Likes: 266
Posts: 8,756 Likes: 266 |
You can always warm them up with the heat gun before installing them. Then some rubber lube to help them slide into place. Those rubbers really can be a pig. They were too stiff from new and caused instruments to have an early lifespan. Hence why they used the full rubber cups later on.
But I have reused original rubber mounts that have hardened with a bit of warmth and some Vaseline.
Posts: 1,931 Likes: 62
Posts: 1,931 Likes: 62 |
in time they will develop a split or 2 around the top edge, ok it doesnt look flash but leave them unless they are real bad, makes getting speedo/tacho out way easier ..
..if you want a pig try the A10 narcel one ....damm near impossible to get the speedo sitting straight
Posts: 41 Likes: 4
Thanks for all the reply’s. The ones I bought were a cheaper aftermarket set that were not the best , but after lots of heat and fluid manipulation I managed to get them together...what a pain!
Thanks again.
Nate.
Posts: 806 Likes: 21
Posts: 806 Likes: 21 |
I use P-80 Emulation on all rubber installations. It may seem expensive but once you use it you’ll never go back to anything else.
Allan G |
Posts: 1,521 Likes: 51
Parts Dealer
Parts Dealer
Posts: 1,521 Likes: 51 |
I found the new ones on the market to be a problem, one of the reasons why we stopped stocking them years ago
Someone was selling NOS rubbers on eBay, much easier fit over the gauges and onto the cup
