Gary Caines
Gary Caines
Hiawassee, Georgia USA
Lannis 63
Lannis 25
NickL 24
Lil Dave, OWhatAThrill, Mountain Rider, ToddK, JohnS_au
11,995 Registered Users
2 members (TR7RVMan, gunner), 19 guests, and 19 robots.
Topics75,325
Posts758,924
Members11,995
It often sits for a month and the oil level in the tank stays the same..
The engine has about 50 psi pressure at 3000 rpm and 20 at idle warmed up with 20/50..
Is the non wet sump situation due to the carefully fitted stock ball check next to the main bush or the original but decent condition oil pump.?
Parts Dealer
Parts Dealer
- yes
Must have a good non leaky oil pump as well.
The oil pump gods are smiling on you.
So the ball check valve alone is not enough tp prevent wet sumping?
The leaks often start before the check valve, usually the oil pump bottom plates, upper body, through the drive spindle, additionally, oil can seep from the high-pressure gears through to the scavenge gears.
Not only that but there may be leaks between the crankcase and the pump body.
Sounds like you've got a good one of its not leaking, either that or you're using extra-thick oil.
Make sure oil is actually returning to the tank in good quantities as it could be the supply side is somehow compromised despite the decent pressure.
I say that HB deserves a "golden attaboy" for building an A10 that doesn't wet sump. That's not so easy an accomplishment.
The anti-sumping check ball and seat need to be perfect, the pump needs to be tight internally or machined for o-rings and you can't have leaks at the gasket.
Both of my A65s wetsumped for around forty years until I fitted a cast iron pump from a '71, and I had tried the check ball remedies of lapping and spring replacement. Now, no wetsumping, even all winter.
YOU ARE EITHER VERY LUCKY OR YOU HAVE NOT CHECKED YOUR OIL.
The Devil is in the details.
2001 Kawasaki W650
Iron pumps should be lapped, mazak pumps should have a new ball tapped against the seat to re-form the sealing face (then discarded and another new ball and spring fitted to the motor). That might have solved the issue, The Iron pumps were inherantly better though in all aspects.
And you didn't read my original post...
