Les P
Les P
quinten 65
kevin 60
DavidP 59
Lannis 23
MikeG 20
MartyH, Steve Sewell UK, BrokenLeg, Jeff Keller, Steveland
12,212 Registered Users
3 members (Magnetoman, Oil Changer, desco), 12 guests, and 23 robots.
Topics76,552
Posts776,406
Members12,212
Most Online204
Jul 10th, 2022
Alexp Offline OP
What am I doing wrong!? I have the bolt removed and it still won’t budge!
Any help is greatly appreciated!
Alex
What year is your B25? Fixed or folding footrests, Canadian bike could be either I suppose?
They differed for home and export models, and for various years...
Alexp Offline OP
I have a 1970 b25. Front foot pegs don’t fold up, but rear do. My bike is a weird one as it has an aluminum tank, with a lovely shape! It could simply be an amalgamation of things, but I’m certain this was a North American market bike! I don’t know anyone else with this tank though on a B25!
You have to 'break' the taper on which the foot pegs are mounted.
Alexp Offline OP
Thanks Larry! WhTs the easiest way to do that? Rubber mallet? I just don’t want to start hitting it blindly!
Alex
A rubber mallet or soft face hammer may work. Perhaps a shot of WD-40 or similar first (give it some soak time first). Can you tell if there is any rust present? If this is a restoration and the present paint finish is not an issue, some heat may work. Your goal is to heat the female taper on the foot peg so it expands a bit. Then rap it with the mallet.
Tom B.
Alexp Offline OP
Thanks Tom! I’m redoing the frame paint, so if need be, I will use heat. Currently I have some liquid wrench on it, and will leave it overnight! Can’t tell if there is rust or not! Fingers crossed!
Alex
Alexp Offline OP
It worked! Success! Thanks again everyone, and please pardon all the b25 threads I’ve started. I’m learning a ton though!
Alex
1 member likes this: Morgan aka admin
Originally Posted by Alexp
It worked! Success!
What specifically worked? Tapping it with a mallet, heat, WD40, a combination of all three?
1971 BSA A65 650 - Project
Always remember the old adage ........ if it moves and it shouldn't , weld it......... if it doesn't and it should, hit it. If it still doesn't, hit it harder.
............ then once you have well and truly munted the thing up, weld the bugger back together again
Alexp Offline OP
Hi! I put some liquid wrench on it, let it sit for about 12 hours, applied a bit more, and let that sit for another 12 hours. A couple taps with a soft mallet and it popped off!
1 member likes this: SpeedyV
Alexp Offline OP
Hahahaha! Words to live by!
