Topics76,552
Posts776,412
Members12,212
Most Online204 Jul 10th, 2022
Posts: 214 Likes: 3
Posts: 214 Likes: 3 |
What am I doing wrong!? I have the bolt removed and it still won’t budge!
Any help is greatly appreciated!
Alex
Posts: 2,129 Likes: 104
Posts: 2,129 Likes: 104 |
What year is your B25? Fixed or folding footrests, Canadian bike could be either I suppose? They differed for home and export models, and for various years...
Posts: 214 Likes: 3
I have a 1970 b25. Front foot pegs don’t fold up, but rear do. My bike is a weird one as it has an aluminum tank, with a lovely shape! It could simply be an amalgamation of things, but I’m certain this was a North American market bike! I don’t know anyone else with this tank though on a B25!
Posts: 1,736 Likes: 11
Posts: 1,736 Likes: 11 |
You have to 'break' the taper on which the foot pegs are mounted.
Posts: 214 Likes: 3
You have to 'break' the taper on which the foot pegs are mounted. Thanks Larry! WhTs the easiest way to do that? Rubber mallet? I just don’t want to start hitting it blindly! Cheers, Alex
Posts: 23 Likes: 1
Posts: 23 Likes: 1 |
A rubber mallet or soft face hammer may work. Perhaps a shot of WD-40 or similar first (give it some soak time first). Can you tell if there is any rust present? If this is a restoration and the present paint finish is not an issue, some heat may work. Your goal is to heat the female taper on the foot peg so it expands a bit. Then rap it with the mallet.
Tom B.
Posts: 214 Likes: 3
Thanks Tom! I’m redoing the frame paint, so if need be, I will use heat. Currently I have some liquid wrench on it, and will leave it overnight! Can’t tell if there is rust or not! Fingers crossed! Cheers, Alex
Posts: 214 Likes: 3
It worked! Success! Thanks again everyone, and please pardon all the b25 threads I’ve started. I’m learning a ton though!
Alex
Morgan aka admin |
Posts: 7,692 Likes: 167
Posts: 7,692 Likes: 167 |
What specifically worked? Tapping it with a mallet, heat, WD40, a combination of all three?
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
Posts: 267 Likes: 37
Posts: 267 Likes: 37 |
Always remember the old adage ........ if it moves and it shouldn't , weld it......... if it doesn't and it should, hit it. If it still doesn't, hit it harder.
............ then once you have well and truly munted the thing up, weld the bugger back together again
Posts: 214 Likes: 3
Hi! I put some liquid wrench on it, let it sit for about 12 hours, applied a bit more, and let that sit for another 12 hours. A couple taps with a soft mallet and it popped off!
SpeedyV |
Posts: 214 Likes: 3
Hahahaha! Words to live by!
