How to find my own threads?
by reverb - 11/20/21 3:55 pm
umjwh
umjwh
Lowell, Ind
Rohan 74
NickL 73
11,920 Registered Users
3 members (Magnetoman, Tridentman, Doug P), 23 guests, and 20 robots.
jesslp Offline OP
Hello everyone!
Well, I’ve just purchased my 3rd A65. It is a 1970 lightning from what I can tell. My question is
The battery was removed and the po had a capacitor. I am switching back to a battery.
On the Tympanun there are two yellow wires going to the stator, one red wire going to ground and
from that ground the red wire continues to the capacitor. Then a black wire from the tympanum going
to the capacitor. If I remove the capacitor and take the red wire to + batt from ground and the black wire
to - batt would my job be done?
Thanks for all the advice
Yes, the capacitor is hooked up in place of the battery. Don't forget to fuse the battery - I like my fuse to be between battery (+) and ground. Don't mess with glass fuses; they have nice inline fuse holders for those square fuses as used in today's automobiles; look in Autozone or your favorite auto parts supplier.
jesslp Offline OP
Thank you Mark
+1.
If the capacitor is working ok, I would be inclined to keep the cap in circuit. again, if you haven't already I would put a fuse between the cap and earth or feed side of the loom (either is fine, but I would do it the same as what you have done with the battery).
Jessip, your existing setup is positive ground and if everything is working ok then you might want to consider remaining positive ground. Your proposed swap changes the polarity of your electrical system. Any diode that is installed and intended to pass current with the existing positive ground will no longer do so when the polarity of the system is swapped.
Hey, you may already know you are swapping polarity, but maybe not.
he has not proposed changing the ground .
He is only swapping a polarized capacitor... wired pos. ground
For a polarized battery ... also wired pos. ground
The capacitor can live without a battery ... pre-existing condition.
The capacitor can live in parallel with a battery .... an option
A battery can live without a capacitor ... the plan
Plus is wired to ground , for both capacitor and battery .
quinten, hey! You are right.
