How to find my own threads?
by reverb - 11/20/21 3:55 pm
umjwh
umjwh
Lowell, Ind
Rohan 74
NickL 73
11,920 Registered Users
3 members (Magnetoman, Tridentman, Doug P), 23 guests, and 20 robots.
qbeanie Offline OP
After a long delay I’m starting back to replace the old carbs with new. After removing to old carbs, I found an oring, thin paper gasket, and a slightly thicker (~1/8”) fiber gasket. I assume the fiber gasket is an insulator. Is the paper gasket required as the new carbs were only supplied with an oring?
Also a split washer is missing on the studs. Is there a specific washer to be used or can a washer sourced from oval hardware be used.
Thanks in advance
50+ years experience
Generally the paper gasket is placed against the cylinder head, then the insulating block, then the o-ring in the cut groove on the carburetor mounting flange. The parts book shows a 42-4476 5/16-26 Nyloc nut as original fitment. 42-4476 supercedes to 37-1691. A split washer would not be called for in this application, however it would be recommended to use a thin flat washer under the Nyloc nut.
-Dave
2 members like this: joe czech, Allan G
With Dave all the way, except that the original nuts were not Nylok in 1967. Nevertheless, Nyloks are definitely the way to go, as these nuts should be tightened only a tad past finger tight, maybe 5-6 ft. lbs., so as not to distort the flange on the carb.
FWIW .
I use a soft ish thich compound gasket between the Tuffnol & the body so dispense with the O ring
I think Enfieds had no O ring .
The softi gasket dforms into the o ring hole to make sure the carb is saled and the fact the flange is supported under the studs aids in preventing flange warping ( as goes thin nuts & a gentle touch )
FWIW, i upgraded my 66 spitfire with new AMAL premiere's and used a 1/8 insulator sandwiched between two paper gaskets, plus original locknuts (w/ no washers pre factory). whether paper or O-ring, most likely it doesn't matter - just don't use an O-ring with a gasket on the same sealing surface. i used a paper gasket because i feel it seals better than O-ring against the phenolic insulator. fairly sure O-rings are designed for sealing against a metal surface. (just my personal preference and my 2-cents).
I use a spring split washer under the nyloc, as I tighten I stop as soon as the spring split washer is flat I stop turning the nut. Never had a flange bend or a carb coming loose since starting this scheme. I use carb with O ring, double thickness 1/4" heat insulator, paper gasket, head.
