How to find my own threads?
by reverb - 11/20/21 3:55 pm
kommando
kommando
NickL 79
Rohan 77
kevin 22
11,924 Registered Users
8 members (bsalloyd, BSA_WM20, 2ndchildhood, DJinCA, Robbo6, BrizzoBrit, Mark Z, kevin), 21 guests, and 19 robots.
#861751 10/26/21 7:58 pm
Looping Offline OP
Hello everyone
I have a vintage flat track project in a homemade frame. I have an A65 thunderbolt engine almost complete with lightened vilo and dual carb head.
SRM do not have any more big bore kit so this engine will stay 650cc
i am looking for "timing side bearing conversion" I believe I have read all the subject matter on this subject but if certain some people have opinions or even photos on the modificationon modification for lubrication I am a taker
If some people have information to share on the preparation of these engines for the flat track, I will be delighted.
thanks
Lucas
You may be better off with a 650. A lot of BSA’s that worked well on a flat track were 650’s.
A 360 degree twin has to do a balancing act between power and traction on dirt. Too much power, you spin coming off the corners. You also gear to run the entire straight….same reason, you need traction on corner exit.
Don’t lighten the crank, stock weight works. A heavy billet crank, if you can find one, works better. Best rods you can afford.
Don’t be tempted to go too high on compression. You lose low end with high compression. Likely 32mm carbs will be big enough.
Single row primary using Triumph/A10 4 spring clutch improves reliability of the primary. Dirt track beats the snot out of a BSA primary.
Just don’t overbuild the engine for power. You will likely be disappointed
You can use a straight heavy series roller and put a bearing outside the alternator and one behind the clutch, then the triplex will stay together and you have end float in the crank covered. There is actually a L/hand thread bicycle pedal mount you may be able to screw on the end of the crank and make an oil feed spigot. You can tee a gage and oil line off a Tee at the oil pressure switch port. Run a pipe and oil into a fitting in the inner case and into an oil seal area on the end of the crank. You do not need 750cc just a good head. I have some posts on that on the BSA forum and here if you can decipher the ramblings.
You could use 32mm carbs or 34mm, just that 34s kick in pretty hard when right open. It needs balancing so you can hold onto it. 34mm give good response from low rpm which is what Rich is recommending. But high flow and speed deliver that with 34s, low speed and bad port shape doesn't.
NKIS 30.
Bearing and mount. This means at rpm the alternator will not run into the stator. And the chain will run in line.
You do not need the 5speed but you need the 3rd mainshaft bearing. Ed V has them and high quality pistons at a good price, MAP have high speck light steel rods.
It needs balancing for rpm (factory raced with 56%) and good valve springs SRM have race springs that shimmed right will allow 9,000, not that those rpm should be necessary, they are not overly heavy.
Depending on the head, basically the std clutch will not work. It needs the heaviest race springs you can get and the narrow 7 plate kit or something similar and probably a packer, plus auto trans fluid in there.
This head is for std valves which would be fine, but 42mm give you more flow and lots of drive. I'm using these carbs on the road and flow can be around 53% more than stock so the bottom end can be pretty much stock cam and compression and still have a very strong responsive engine.
It would need good breathing filters.
Looping Offline OP
Thanks a lot for your informations, i will study all this.
If someone has the weight of the original crankshaft I could compare with mine.
I am also looking a technical instruction for rebuilt valve seat do you have this ?
Lucas
Yet to machine this but Ben found a pedal mount commonly available for push bikes with the correct left hand thread. It needs to be the correct length but can make a spigot for the crank that screws on the end. I've had these made before but this looks like an easy starting point.
2 members like this: PEH, NickL
PEH Offline
Hi Mark, Would you have any jetting/needle info for the flatslide carbs, i have a pair of 32's id like to fit on an A65 Trackmaster flattracker i built.
The pwk34s I use have 150 main jets. But they a 34s on a head that flows 167cfm.
PEH Offline
Thanks Mark, Is there a needle that works best, or just the one that came with the carb?
The std one works, I have different ones fitted. I imagine the porting effects it. But in any case setting up a wide band oxygen sensor and air fuel gauge could establish the settings fast. And the road isn't a great place to be looking at that. Ben has one on his BSA and it could be easier to read as it isn't that bright.
On a dyno it would have one up the exhaust end as well to compare and would be more ideal. Ben's is very fast acting and dialing in 12.5% for wide open sort of easy, and at other points, but some places are lean or rich and a bit hard to pin point throttle position. A dyno would be the place after getting it to run through the range. and marking the twist grip. Then recording the readings at each point.
I really need to do that with the Firebird so I know exactly what works with the 34pwk and this type of port. But the 150 main seems pretty good.
1 member likes this: PEH
PEH Offline
Thanks again Mark. I have a dyno i use just up the road at Mallory Park, I will give it a go.
Looping Offline OP
I come to give you some news.
On your advice, I received MAP steel rod and I am about to order ED V pistons.
For the lubrication system, the person who sold me the engine invited me to come and see his modifications to these engines.
I took some pictures here.
thanks to her
[Linked Image from zupimages.net]
We use a bearing ref NKI 38/20 XL and will start machining and assembly next week
concerning the head engine, a cam to advise me?
I was thinking of using an spitfire cam, any reviews?
I am also thinking of using Mikuni vm 32.
I read all the subject of Mark Parker on the cylinder head but I am a little lost, would you have any advices and photos on the preparation of a cylinder head for 32mm carbs and which diameter of exhaust would you use?
I have made good progress on the frame and I will be able to concentrate on the engine.
Thank you for your answers
Lucas
Instead of the external oil line you might consider moving it inside. You can intersect the pressure side down to the OPRV and put in a post to the outer timing cover then route it to your end feed boss. A little safer than having a low external line on a flat track bike.
Hi. Very interesting build.I love the flat track look. Im in a similar situation working on an end feed system. On your friends engine Can you tell me how the oil seal housing on the end of the crank is held in place?
Thanks Ben
Looping Offline OP
it's welded
Looping Offline OP
DMadigan
I don't think I have a problem with the external passage, the passage will be made in flexible
Is the cover still straight?......welding is usually bad news.
The easiest way of obtaining a hidden oil supply is to drill
the gallery through and use a hollow oil pump stud then
bring it up through the timing cover. But there are so many
different ways to do this mod. The feed should be at least
4mm id tube really, taking the supply from the switch has
a restriction and will need drilling out.
Don't forget to blank off the main bearing feed or just use
plug with a 1mm hole in it to supply the bearing.
Moderated by  Allan G
