7 members (quinten, R Moulding, David in Atlanta, jimmymckenna, Magnetoman, PINEMONKEY, Vincent Esposito),
43
guests, and
16
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,031
Posts769,175
Members12,118
Most Online151 May 8th, 2022
Posts: 193 Likes: 6
Posts: 193 Likes: 6 |
g/day i have just purchased an 850 project with a long range tank it does not seem to fit the frame properly it seems to sit too close to the head stock were the long range frame different ???
Posts: 11,623 Likes: 251
Posts: 11,623 Likes: 251 |
No, mine fits fine on a standard frame, the frame mounts have large holes so you can loosen the nuts on the 2 front tank studs and pull the tank back. If that's not enough then then the frame mount brackets may need surgery, positioning was a bit hit and miss.
Posts: 5,313 Likes: 76
Posts: 5,313 Likes: 76 |
g/day i have just purchased an 850 project with a long range tank it does not seem to fit the frame properly it seems to sit too close to the head stock were the long range frame different ??? Do you actually mean the Interstate model (below) tank and not long range 750 'LR' model tank? Assuming it is steel and not fibreglass is it a genuine tank or one of the 'Made in India' reproductions? [ Linked Image]
Last edited by L.A.B.; 09/01/21 7:16 am. Reason: Having difficulty finding a pic link that shows the image
Posts: 4,647 Likes: 77
Posts: 4,647 Likes: 77 |
Ah, the Interstate tank is a different kettle of fish, entirely. I've got a NOS sample of one, its one of about half a dozen different versions that appeared. Twin pinstripes signify an 850 version - the 750s had a single (wider) pinstripe. Pic, selected at random. ![[Linked Image from dn3bmh8yk8vvw.cloudfront.net]](https://dn3bmh8yk8vvw.cloudfront.net/wEalW4IeK2joNw-yowQXXgpG1IA=/10058.JPG) Interstate mufflers would be lower and flatter... There are several different versions of fork yokes. Some may or may not work with various tanks. It would be best if you had ones for the disk brake, and then work from there.
Posts: 1,662 Likes: 24
Crew Chief
Crew Chief
Posts: 1,662 Likes: 24 |
There are several different versions of fork yokes. For an 850 which is a 2B rolling chassis - exactly 2 TT sets... regular 850 and MKIII ....only by mix and mismatch other parts should offend a tank
Posts: 193 Likes: 6
well looking at L.A.Bs. photo it seems it is an Interstate tank also it is a f/glass one of very good quality , I will try again tomorrow
well looking at L.A.Bs. photo it seems it is an Interstate tank also it is a f/glass one of very good quality , I will try again tomorrow Fibreglass is very likely to be genuine but almost certainly a 750 Interstate tank. http://www.classicbike.biz/Norton/Brochures/1970/72NortonBrochure.pdf
Posts: 236 Likes: 7
Posts: 236 Likes: 7 |
You better seal the tank first!!!
Posts: 193 Likes: 6
Well it looks like 750 f/g tank as it has only 1 stripe around it and a 850 frame and engine ,i thank you all for that info baz
Posts: 163 Likes: 15
Posts: 163 Likes: 15 |
. Yes Rohan, from memory the interstate pipes had a double set in them so that the mufflers were nearly horizontal, in order to provide room for fitting panniers.
1954 Norton Dominator 88 cafe - Yamaha wheels, Lyta tank ( project in progress) 1969 Triumph Bonneville Currently 6 other non-Brit machines. Past history includes 11 Brit and 13 non-Brit machines. Some impressive and some just silly.
Posts: 615 Likes: 7
Posts: 615 Likes: 7 |
I've never laid eyes on the genuine (LR) article - but they were only fitted to 750cc models (as new).
Posts: 615 Likes: 7
Thanks Les.
Interesting stuff. Wonder who in Nortons (?) dreamed that up. Good to see old threads never die .. Cheers.
Posts: 615 Likes: 7
That might depend on which came first, the Interpol (with no radio cut out in the tank top which might have been with and without) or the LR Fastback in the first half of the 1971 year. My brother was a MOT rider from around 1973 onward and still remember the cop issue Commando, breadbox tank Triumph 650 and later 750/4 he rode. (but do not recall the Commando having a different tank to stock) Maybe the LR tank was an idea from the Interpol. (or not)
My Interpol tanks with Radio cutouts have exactly the same Atlas top and the bottom made from lots of pieces of steel welded together. https://www.nortonownersclub.org/models/Commando/norton-models-commando-interpolDesigned by Neale Shilton specifically for the police in home and export markets, the Interpol is one model that nearly didn’t get made, but went on to become one of the longest running Commando models. It was unveiled in 1969 and produced from 1970 to the end in 1976. Early versions started out with a modified Atlas tank (in one of four variants to accommodate the radio) and an Avon fairing. As the Interpol predates the LR then the Interpol must have been the inspiration. Tanks were made by A. J. Homer and Sons, Stirling Road, Shirley, Solihull.
Tanks were made by A. J. Homer and Sons, Stirling Road, Shirley, Solihull. Thanks K. Do we know if they only made Interpol tanks, or did they do other tanks for Norton ? https://www.gracesguide.co.uk/A._J._Homer_and_SonsNow Stirling Rd looks to have changed very little over the past century, and is quite short, do we know which building they were ? Or what happened to them ?
A J Homer made tanks for all the majors including alloy tanks. No more info than that other than a rumour they were pissed off with Norton at all the effort doing the Interpol tank and not to get the other tanks after the change to steel from fibreglass mandated in 72.
No doubt the penny pinchers in the accounts dept had something to do with that. ? Wonder where they did go to get them done then
