by C.B.S - 09/28/21 6:22 pm
No Name Man
No Name Man
SE Ohio
Rohan 82
koan58 20
11,876 Registered Users
3 members (JubeePrince, Tom A65LR, gunner), 31 guests, and 54 robots.
Does anyone know if the speedo cable lengths of the standard mounted speedo and the nacelle mounted speedo are different lengths? And what the length of the nacelle one should be?
It can't be too much different but maybe a few inches longer?
Thanks, guys
Mine measures about 42 inches and has the early divers helmet nacelle on a 56 A10
This was measured installed so could be off a bit
Keep It Greasy
Thanks Salty ...now i need to find the length of the NO nacelle cable ...my nacelle is the one like yours
So does anyone know the STANDARD speedo mount ( non Narcelle ) cable length on the A10
from "salty " nacelle one is approx. 42inches
thanks guys
*** SALTY""
was the 42 inches you said an OVERALL length including ends of inner cable
OR was it the overall length of JUST the outer between the ends of the crimped on fittings ?
cheers
That 42 inch rough measure was just the black outer between the end ferrules/fittings
I don’t have a cable off a bike to measure
For what it’s worth my 1954 B33 in a swing arm frame without nacelle has a black outer cable length of about 44 inches
Speedo mounts centre of top triple tree in front of steering damper knob
Check out Draganflys website there’s some good info there that might help
Keep It Greasy
