How to find my own threads?
by reverb - 11/20/21 3:55 pm
Kevin E
Kevin E
Hull, East Riding of Yorkshire, England
NickL 76
Rohan 74
11,920 Registered Users
0 members (), 16 guests, and 21 robots.
#859021 09/21/21 1:37 pm
Quick question please?
Can B31 cylinders be used on a B33 bottom end? Any problems _if_ they can physically be mounted on the cases?
Thanks, Ron
Or; Put another way. Can a B31 cylinder be bored out and used on B33 cases???
Thanks, Ron
Hi Ron
Yes the crankcases are the same so the B31 cylinder will fit
But you cannot bore the B31 cylinder to the 85mm size of a B33
Some people bore the B31 cylinder to 76mm and use a Triumph piston to get near 400cc
Not exactly straight forward as I believe the crank needs re balancing to avoid bad vibration ??
crank does not need to be balanced, also you can take out to 79mm b44 piston
A7, A10, B33, B31, A65, C15, T100
Bantam
1 member likes this: SouthendMike
