by C.B.S - 09/28/21 6:22 pm
Roadwarrior
Roadwarrior
Nor Cal near Sutters mill.
Rohan 82
koan58 20
11,876 Registered Users
4 members (NYBSAGUY, Hugh Jörgen, bill50cal, pushrod tom), 35 guests, and 57 robots.
#859668 09/30/21 1:17 am
Any thoughts on the amount and viscosity of oil for the M21 telescopic forks ?
BSA service sheets say 142ml of 20wt
Haynes Manual says 213ml ..
My forks are a bit 'clunky' on the rebound and in general...I had 220ml of 30wt engine oil in each leg.
More oil ? .. thicker oil ? to stop the 'clunkiness' .
Thanks friends ...Charlie.
M20 forks predate 2 way damping so they will always be klunky on the rebound.
There are upgrade kits to convert then to two way damped rod damper style .
Thanks Trevor,can you give me details about where I can source the update kit please ??
... also,for the moment,do you have any thoughts on wt/amount of oil in each leg ? (1953 M21) .
According to BSA service sheet 706 printed in August 1963 M20 M21 M33 142cc of oil in each fork.
AFAIK, Paul Goff in the UK has an upgrade kit for BSA forks that contain the Dow style damper rods. There are also some drawings online somewhere that show how to make them if you have access to a lathe.
The Dow type dampers help a lot. But I had to do a lot of playing around with oils to find dampening I liked. Most oils recommended for BSA forks, are, IMO too harsh with Dow dampers. I am running 7.W shock/fork oil and the forks are really plush.
The Dow conversion reduced the travel. Don’t know about modern versions.
If your spring length and rate and oil viscosity are right, normal road riding shouldn’t make the forks reach full extension very often.
After all, it’s the rebound movement that has damping.
Charlieboy #859745 10/01/21 12:35 am
Hi Charlie,
If the fork legs are in good condition it is worthwhile to drill the 2 bleed holes in each one, as done on the later A,B&M models
This and the later oil quantity stops the forks topping out mechanically by trapping oil between the bushes near full extension
The top bushes need to be held tight by the circlip to stop noise, thin shims will break up in service, its better to machine off a few thou and use a thicker shim.
Adding the Dow type damper rod does not affect the travel unless you also fit the longer top bushes
I found that extra oil was needed to keep the damper valve submerged on full extension, as Rich says use fork oil and experiment with viscosity to get the effect you are happy with
Good one John,thanks for your thoughts mate .. I'll look into that.
