9 members (Hugh Jörgen, Ian Ashdown, jimq, MikeG, NickL, Richard Kal, quinten, koan58, Royaloilfields),
28
guests, and
16
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,052
Posts769,394
Members12,120
Most Online151 May 8th, 2022
Posts: 8,053 Likes: 91
Born To Run
Born To Run
Posts: 8,053 Likes: 91 |
Time for some help from the collective hive.
First this is a running bike. I’m transitioning to some LED lights, replacing oil lines, adding external oil filter, getting rid of two(!) oil coolers and generally inspecting systems.
It appears the bike is wired with the original zener, rectifier AND 3phase voltage regulator. Aren’t the zener and rectifier removed from the circuit when a voltage regulator is installed?
TIA,
'77 T140J Silver Jubilee '82 T140LE TMA Royal ‘69 BSA Rocket 3 (patiently awaiting it's turn) "Vintage Bike". What's in your garage?
Posts: 5,319 Likes: 76
Posts: 5,319 Likes: 76 |
It appears the bike is wired with the original zener, rectifier AND 3phase voltage regulator. Aren’t the zener and rectifier removed from the circuit when a voltage regulator is installed? Yes.
Born To Run
Born To Run
Thanks Les. The previous owner did not disconnect them, so the regulator was wired in the circuit to the three alternator wires I have removed the original zener and rectifier. I sent a message to the PO asking why. Perhaps to provide redundency?
Born To Run
Born To Run
Just to double check -
I have two sets of alternator leads coming out of main harness. One for the 3 phase rectifier and one for the 3phase zener.
There is also the NU (brown blue) wire for the zener. I should be able to heat shrink those seven connectors now that I have just the 3 phase Sparx regulator wired on the bike,
Correct?
TIA,
There is also the NU (brown blue) wire for the zener. Do you mean rectifier? ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/yxkh8cNM/Triple-Zener.jpg) I should be able to heat shrink those seven connectors now that I have just the 3 phase Sparx regulator wired on the bike,
Correct? Assuming the Sparx regulator is connected directly to the three alternator AC wires (WB, GB, GY) and also assuming the Sparx positive wire is connected to NU somewhere or is connected to battery(+) then, going by the diagram I would say yes.
It's obviously an earth/ground/negative wire due to where it has been attached (along with the black from the Sparx?) so I'd guess a PO has used a length of red as there's no indication of what or where that particular 'red' wire connects to, but it doesn't appear to be the Sparx box red. I believe the Lucas RITA box (conspicuous by its absence in any pics) would normally be mounted to the rear of the LH airbox casting by the two 'L'-shaped brackets where the Sparx box was, so where is the RITA or other EI box and could the 'red ground' wire be something to do with it or perhaps a ground to the battery negative terminal for the Sparx?
Born To Run
Born To Run
Oops. Yes. Rectifier. Assuming the Sparx regulator is connected directly to the three alternator AC wires (WB, GB, GY) and also assuming the Sparx positive wire is connected to NU somewhere or is connected to battery(+) then, going by the diagram I would say yes. Yup. Thanks for confirming. Steve
Born To Run
Born To Run
It's obviously an earth/ground/negative wire due to where it has been attached (along with the black from the Sparx?) so I'd guess a PO has used a length of red as there's no indication of what or where that particular 'red' wire connects to, but it doesn't appear to be the Sparx box red. Correct. The length of red wire with yellow ring terminal was connected to the the white wire of the a Boyer MkIV (negative ground) I believe the Lucas RITA box (conspicuous by its absence in any pics) would normally be mounted to the rear of the LH airbox casting by the two 'L'-shaped brackets where the Sparx box was, so where is the RITA or other EI box and could the 'red ground' wire be something to do with it or perhaps a ground to the battery negative terminal for the Sparx? Yes, that length of red wire was negative ground for the white wire off the Boyer box. Ring terminal on one end, spade on the other under the seat. Thanks for that info about Rita mount. I was wondering who built that bracket The Rita was replaced with a Boyer MkIV at some point (was mounted on the timing side on a piece of plywood wired to the frame seat loop). I asked the PO if there was a reason he didn't disconnect the zener and rectifier when he installed the Sparx regulator his reply was "I don't know, it didn't affect anything."(!) As this bike was running before I delved into it, apparently you CAN wire a SS regulator in parallel with the zener/rectifier! Cheers, Steve
Born To Run
Born To Run
Electrical system is sorted. Next: gearbox. Ugh.
Had to pull the outer cover off of gearbox to replace oil lines. Gear oil sitting on bottom of inner cover when I pulled the outer cover was almost silver in color.
Gonna need the collective hive mind for this one. Put a magnet in it to confirm the presence of steel. Looks like I’m pulling the inner cover. I’m hoping it’s nothing too catastrophic. The bike was last rode in April.
More will be revealed when I pull the primary cover, clutch and inner gearbox cover.
Stay tuned,
Gearbox oil. Ugh.
Steel on magnet
Gordon Gray |
Posts: 585 Likes: 62
Posts: 585 Likes: 62 |
Take a quick look at the kickstart spring and ratchet - if the spring is to correctly tensioned, it will hit the ratchet assembly.
Born To Run
Born To Run
Thanks, Tink, did that. Looks good at this point
Born To Run
Born To Run
Posts: 1,768 Likes: 31
Posts: 1,768 Likes: 31 |
My ‘82 Electro is bone stock except for the Pazon.. It has the 3 capacitor pack, and diodes. Got her started for the first time last night, putting out 13.5 plus or minus a volt or two. Almost done!
1968 BSA Firebird “Scrambler” 1982 Triumph T-140 “Electro”
Born To Run
Born To Run
Born To Run
Born To Run
Deeper into the gearbox we go. Fishing around with a magnet in the bottom of the gearbox/gearbox oil I found needles from a bearing.
The needle bearing in the inner cover is OK, so it's either the layshaft needle bearing or the two needle bearings in the high gear assembly. Finally got everything stripped away, gear cluster comes out tomorrow so hope the damage is minimal.
More will be revealed!
Needle rollers
Posts: 5,441 Likes: 404
Posts: 5,441 Likes: 404 |
The gift that keeps on giving.......we feel your pain and understand the quest. Thanks for taking us along.......Gordon
Born To Run
Born To Run
And the offending culprit:
Hope it’s a simple matter of flushing out the gearbox, replacing the lay shaft needle bearing and putting it back together after parts are inspected for damage, wear, etc…
Posts: 2,145 Likes: 150
Posts: 2,145 Likes: 150 |
Hi Steve, Was high gear rubbing case? Looks like something was?? Don
Born To Run
Born To Run
Hi Don -
Doesn’t look like it unless you see something I don’t?
Perhaps some needle bearing bits when it first got chewed up?
High gear assembly
High gear assembly (other side)
Born To Run
Born To Run
Born To Run
Born To Run
Born To Run
Born To Run
Posts: 3,883 Likes: 43
Posts: 3,883 Likes: 43 |
Hi Jubee Prince; seeing your post #86 1112 the photo "primary wear" showing the indentations of the chain adjuster etc; I have the same problem; I am thinking to refill there with aluminum. Or that is not possible due to the holes? Do not know another way to fix that anyway. What will you do regarding that?
Born To Run
Born To Run
Reverb -
It wore some aluminum away, but not all the way through. No repair in that area needed.
