Topics76,758
Posts787,766
Members12,432
Most Online230 Mar 11th, 2023
Posts: 3,823 Likes: 81
Posts: 3,823 Likes: 81 |
The center stand stops on my 72 are so hammered that the stand now goes too far forward. So far as to have both wheels touching the road and it is VERY hard to get the bike off the stand. Any clever, easy fixes other than adding some metal to the stops by welding? There are no welding shops in Bishop anymore.
Posts: 977 Likes: 45
Posts: 977 Likes: 45 |
Maybe use a split rubber hose around the center stand secure with a zip tie to act like a bumper moving the center stand back to its normal postion when resting against the frame stops?
1955 BSA Bantam D1 Plunger 1956 BSA A10RR Street and LSR Bike 1961 BSA C15S 1966 BSA Lightning 1966 BSA Spitfire - Soon to be an A50 Powered LSR Bike 1969 Triumph T100C 1970 Triumph TR6R 1970 Triumph TR6C 1972 BSA Lightning LSR Bike 1974 Triumph T150V
I've been doing some studying. A .032" feeler gage inserted between the stop and the stop pad moves the bottom of the center stand backwards towards the vertical 5/8 of an inch. Why calculating moon shots are so critical. That looks about right. Maybe some J-B Weld and a couple pieces of the feeler gage???
Last time I checked a new center stand was close to $200. And there is no guarantee that anything would fit correctly. Think I'll try a bodge first. If it works fine. If not I'll go to plan two.
Posts: 919 Likes: 108
Posts: 919 Likes: 108 |
Are you sure the pivots aren't worn, it gives the same symptom?
I've replaced the bolts and that was a huge help. You can see the convex wear on the stops.
Success!!!! For the first time in over 30 years the rear wheel is off the ground when the bike is on the center stand. It has always been the front wheel that has been up in the air. Much, much easier to to get on and off the stand. One of the pivot holes was a bit enlarged so cut a thin strip off a feeler gage and shimmed the shoulder of the bolt. Now even that is a tight fit. Why didn't I fix this 30 years ago? I guess I just don't like to jump into things. HA.
