dirtymartini
dirtymartini
Beaumont, PA
kevin 65
quinten 64
Lannis 59
Lannis 24
MikeG 21
Scott Meredith, JOB, EdinStAug, Ash Cav, MartyH
12,216 Registered Users
6 members (gavin eisler, Hillbilly bike, slow learner, Magnetoman, PINEMONKEY, Jonez69), 21 guests, and 25 robots.
Topics76,564
Posts776,591
Members12,216
Most Online204
Jul 10th, 2022
Novice poster
Novice poster
I have rebuilt this engine and run it but after a short while the smoke was coming out of the head,
I could not find a toque any where so I didn't tighten too much obviously not enough.
Any help would be welcome
Originally Posted by PDF link
A persistent leak from the rockerbox/cylinder head joint can be permanently eliminated by
grinding both mating surfaces really flat on a piece of plate glass with fine grinding compound as
used for valves. Oil will leak down the 3/8" cylinder studs and out the head-barrel joint unless the
O-Ring seals under the washers are renewed whenever disturbed. torque the 3/8" cylinder head
nuts 25 foot-pounds evenly. Pull the 5/16" rockerbox bolts down only until they are firmly tight;
these fine threads strip out of the aluminum head rather easily if forced, but this catastrophe can
be repaired with a Helicoil insert.
pdf link
groveclassicmotorcycles.co.uk/Graphics/Home/velo-technical-instructions.
Novice poster
Novice poster
Thanks great, I appreciate your feedback
Tim
+1 Quinten.
And Copper headgaskets should be annealed before assembly.
