MikeG
MikeG
New Hampshier USA
quinten 91
Rohan 65
quinten 13
makrph, vanGinneke, Gearhard, yornocT120R, robert wilby
11,840 Registered Users
5 members (bill50cal, Magnetoman, Gary Caines, Steve Erickson, GJVGC), 20 guests, and 83 robots.
#854674 07/25/21 9:34 pm
mrcarb Offline OP
I am looking for the part numbers for a 69 A65:
1) The gasket for the inspection cover near the front of the primary cover. The parts list says it is 68-840 but it must be a different number since vendors
do not carry it by this part number.
2) The rubber o-ring for the two primary plugs. The parts book lists 70-8782 as the number for fiber washer but does not list one for a rubber o-ring.
Thank you in advance
https://www.ebay.com/itm/BSA-A65-Tw...f-2-63-73-68-840-Bsa-A65-6-/363253853434
O.E.M Part number is 71-1420 or 68-0840
1970 T120R - 'Anton'
1970 Commando - 'Bruno'
1967 T120R - 'Caesar'
1968 Lightning - 'Dora'
It’s always a good idea to have a box of assorted o’rings. Often one that looks about the right size and thickness will do the job. Especially in this instance.
The parts list says it is 68-840 but it must be a different number since vendors do not carry it by this part number.
Anytime you have a three-digit number after the main category/component number, in this case, 68 being the main category number, you must add a zero or 0 before the existing digits.
Example: 68-840 becomes 68-0840
For two-digit numbers, add two zeroes / 00
1971 BSA A65 650 - Project
i think the part number is the same , or works
70-8782
just add O RING, INSPECTION PLUG, to the search in instead of fiber washer .
same size is used on bsa and triumphs
o-ring size
OD: 1" (25.4mm)
Thickness: 1/6" (1.9mm
the generic o-rings from the hardware store should be
Good enough for this particular application .
for reference
the google says the fibre washers are
OD: 1 3/16"
Thickness: 1/16 ...
Originally Posted by quinten
I think the part number is the same, or works
70-8782
The 1970 parts book lists 70-8782 as an "O" ring. The error of listing it as a fiber washer in the 1969 parts book was probably an oversight when updating from the 1968 and previous years' parts books which specified 40-0239 fiber washers. Basically a copy and paste error facepalm
V
V
For the O rings use 70-7310. Triumph black pushrod tube O rings. Work a treat.
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
