Topics76,525
Posts783,968
Members12,386
Most Online204 Jul 10th, 2022
Posts: 5,251 Likes: 145
Posts: 5,251 Likes: 145 |
I've been using this stuff, and I was happy with it,...before this. Weird, as I was quite sure it was impervious to the dreaded 10% Alky, but I guess not?? I like clear, anyone have a suggestion? Would like both in 1/4 and 5/16" ID. Needless to say, my Ride for the 4th, didn't go as planned. I guess that's why you need more than one.
Down to ‘69 T120R now a Tr6R tribute bike ‘70 TR6C “happy in the hills” ‘67 A65LA (now single carb) ‘93 K1100RS heavy metal (should be gone, still here…)
Posts: 2,092 Likes: 329
Posts: 2,092 Likes: 329 |
I use Tygon tubing which is yellow in colour but see-thru so you can see the fuel, it seems to be impervious to ethanol in fuel and remains flexible for years.
Make sure you use one with the Tygon trademark as there are some fakes around.
Posts: 8,981 Likes: 302
Posts: 8,981 Likes: 302 |
Get some Tygon tubing. It will stay supple and flexible for years. I have the yellow Tygon pushed on to my fittings at present and they have been on there a couple of years, it’s impervious to just about everything that you can use it for on a bike. You can get clear Tygon also, I don’t know if the properties are any different to the yellow stuff but I know it’s fine with solvents and oils, so should be fine with fuels also. You can also get it in various thicknesses.
If your after a brand name, look up Saint Gobain
Now lets all have a beer!
Posts: 5,465 Likes: 273
Posts: 5,465 Likes: 273 |
As Gunner has already mentioned Tygon is the go You can get it in a sort of smoky grey as well But make sure it is branded and there is lots of "fuel line in popular yellow colour" around. I see a lot of it on chainsaws where it crumbles away after a year or so regardless of whether it has seen any fuel or not. Most mower shops will keep it by the roll & not cheap And note that it comes in a couple of different wall thicknesses.
Bike Beesa Trevor
Posts: 4,521 Likes: 161
Posts: 4,521 Likes: 161 |
1972 Triumph T120 1968 BSA A65 1968 MGB Roadster 1979 Chevrolet Camaro Berlinetta 1969 Honda Mini Trail 2004 Honda Shadow Aero 1949 Ferguson TE20 tractor 1975 yamaha xs650b 1971 SL 175 Honda project 2 olive drab WWII military bicycle replicas
Posts: 6,336 Likes: 626
Posts: 6,336 Likes: 626 |
+1 for Tygon. KC-- I got my last roll (clear) from McMaster Carr. HTH
Posts: 549 Likes: 67
Posts: 549 Likes: 67 |
Motion Pro sells Tygon fuel line in black, grey and clear. You can get it at a well stocked motocross oriented bike shop or on Amazon. For Amazon, here’s the 5/16 clear: https://www.amazon.com/Motion-Pro-1...fuel+line&qid=1625590331&sr=8-11
Thanks for the replies,…. I’m checking on the links. As a retired airplane mechanic, I’d be curious if the Air-Tech tubing was used with ethanol gas. I plan to call’em and ask. Will report any answer……. I thought I had used Tygon tubing years ago, had trouble, and thats when I got Superthane from Don Harrell. Anyhow, the consensus here is it works!
i have used the airtech line in all my bikes for years with ethanol and non ethanol fuel
Posts: 7,859 Likes: 198
Posts: 7,859 Likes: 198 |
+1 for Tygon. KC-- I got my last roll (clear) from McMaster Carr. HTH Richard, Is this what you ordered? https://www.mcmaster.com/fuel-hose/material~pvc-plastic/color~clear/ Tygon - Versilon Fuel Line
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
"Charlie don't surf"
Jon— away from home at the moment so can’t check it out definitively but— sure— that looks to be the stuff HTH
Posts: 6,541 Likes: 359
Posts: 6,541 Likes: 359 |
According to this chart Versilon has a mediocre resistance to petro distillates and is poor with ethyl alcohol... Versilon
My bias here is that my stuff gets ridden a fair amount and so while I try to keep standard as built bikes, I often substitute in more modern parts where necessary to make reliable riders.
On fuel line, I have started to use only the Motion Pro stuff. It lasts.
I have no way of knowing for sure, but this stuff is very much like that nearly perfect stuff that comes stock on carbureted Japanese motocross bikes. In fact I have a threesome of 2005-2006 Yamaha two strokes, with the original Japanese fuel lines still on them--and they are all still working fine after 15 years. I don't know how to buy that Japanese OEM stuff, but the Motion Pro seems pretty much the same.
Whatever it is, it is pretty good, and this stuff isn't going to turn yellow, harden and crack, ending your ride dangerously, only a year or two (month or two?) after you put it on.
I pretty much only use this Motion Pro stuff nowadays as the fuel lines age out on my bikes, in the grey version because that's what they have at the Yamaha shop near my house. It may not be pretty or "original", but I am a real believer in safe fuel lines these days. Probably like most folks on this site, I have had many Brit bikes with those familiar hardened yellow vinyl lines that eventually crack, and the straw that broke the camel's back was that I got sucked into using some light green tinted clear vinyl stuff on my 66 Ducati 250 Mk 3, that was supposedly what you used because it was "original." The stuff hardened off and started leaking very quick. Now it has very decidedly "non-original" grey Motion Pro lines on it--to me, it's just not worth the risk to use fuel line that isn't reliable.
Posts: 1,985 Likes: 108
Posts: 1,985 Likes: 108 |
Have you noticed how people are now blaming ethanol in fuel for fuel line problems? Nearly 50 years ago I was fighting with clear fuel lines that had set like concrete and cracked. Rubber fuel lines that shed rubber particles and blocked up carbs. Tygon fuel hose is the dogs danglies
BTW DO NOT use Tygon fuel hose between brake cylinders and reservoir, brake fluid sweats through it
Allan G |
Interestingly both Tygon and Versilon tubing are manufactured by St Gobain and you can see the full range in a PDF at This Link which also mentions the suitability for cleaning chemical dispensing, dairy, food & beverage, small engine etc. use. The Versilon tube on the McMaster-Carr site is number: SE-200, which is apparently intended for food & beverage and other market use. For small engines Versilon C-210-A oil, fuel & grease resistant tube is recommended. That's not to say SE-200 won't work with gasoline but it doesn't seem to be recommended. As for Tygon, the following are recommended for small engine use:- Tygon® F-4040-A, High-Performance Fuel and Lubricant Tubing Tygon® LP-1100, Designed for Gasoline Powered Ground Supported Equipment Tygon® LP-1200, Clear, High-Performance Fuel Tubing for Small Engines Tygon® LP-1500, Designed for Gasoline Powered Handheld Equipment Tygon® LP-1600, Designed Specifically for Outboard Marine Applications
Posts: 93 Likes: 1
Posts: 93 Likes: 1 |
What inside diameter would be needed for a 67 triumph?
What inside diameter would be needed for a 67 triumph? 1/4" ID for the fuel lines.
Posts: 93 Likes: 1
