Myles Raymond
Myles Raymond
Glasgow, Scotland
quinten 89
Rohan 66
quinten 13
11,839 Registered Users
0 members (), 29 guests, and 73 robots.
#851617 06/14/21 10:52 pm
I have been riding around a bit on the A10 project bike... Runs perfect ...except...after about 20 minutes the engine starts to misfires badly on both cylinders. This occurs at 3500 rpm regardless of throttle position or engine load. Below 3500 rpm it runs great and idles nicely. Fiddling with the Manual advance does not clear the problem.The inductive electronic tach needle goes nuts when it misfires. engaging the cold start makes no difference...
The plugs look ok, no signs of obvious carb problems...
The K2F magneto was fully rebuilt, rewinding etc by a man i have used in the past. It came with a test report..
Non resistor NGK iridium plugs, solid core wires with non resistor terminals and so on...
I am going to change the plugs and check the points tomorrow...
Anyone have a mag act up like this?
That sounds like a heat related problem to me. My first guess would be ignition coil but I wouldn't rule out a capacitor either. How long did your guy run the magneto on the test stand?
Disclaimer: My experience is primarily with aircraft magnetos and less with bikes.
One hour and supposedly in a heated situation..
Capacitor packing up.
1 member likes this: RF Whatley
Rather than the capacitor, it sounds like when it gets hot the insulation is giving up at higher rpm (i.e. higher voltage).
1 member likes this: gREgg-K
I would use freeze spray and see if the fault clears.
Dibnah #851652 06/15/21 11:09 am
No need to, it runs fine after a few hour cool down.....
It goes back to the shop....
About the only times the magneto's on my old A10's ever gave me grief it was usually due to one of the carbon brushes not making a good contact with the armature , In your case of both cylinders misfiring i'd unscrew the main earthing brush > It's the slot headed screw next to the identification tag "as can be seen in Magnetoman's Avatar" .. Check it's clean and also that the spring still "Springs" , Next thing is try cleaning the brass armature it runs on - i used to use a small screwdriver with a thin strip of clean rag looped over the end of it & poke it into the hole while slowly turning the engine over , Be aware this can sometimes give you a shock ? .. One other thing to check is the ignition kill wire that's connected between the centre of the points cover and the kill switch .. Is it cracked or rubbed bare anywhere along it's length and so earthing itself out ?.
Remember the faster the mag spins - the bigger the spark ,
At 3500 rpm the energy produced inside your magneto might just be high enough to find it's own rout down to earth
Bodie #851740 06/16/21 3:27 pm
It's definitely worth the time to disconnect the wire at the magneto and do a quick test. The only way that could be a problem is if there is a crack in the wire, or an internal issue with the switch, in combination with a resonance at that rpm. Although that's unlikely, it's not impossible, and it's faster to do the test than to remove the magneto.
Since the magneto was rebuilt, the two most likely suspects are the condenser and the coil. However, the symptoms are inconsistent with condenser failure, so my money is on the internal wiring.
I shipped the magneto to the rebuilder this morning....I built the bike from a pile of parts,everything electrical is new and the wiring is hand fabricated...I did check the obvious, points, pickups, kill switch I even checked the resistance of the spark plugs.On the first longer ride when the ignition acted up I returned, pressed the kill button but the engine keep running. I had previously rerouted the wire, got distracted and forgot to put it on the terminal....
W
Novice poster
Novice poster
W
Hillbilly I am curious you had mentioned you are using "Non resistor NGK iridium plugs" . I also run a mag on my bike and when I was trying to source out new plugs for my machine I looked into the Iridiums but I was told by all the suppliers that Iridium plugs do not come in a non resistor version. Can you clairify this for me please, are your plugs in fact Non Resistor and an Iridium?...........thanks wayne
I bought 1/2 dozen new old stock off ebay for $15..B7EV...A common plug for 2 strokes..
True.
NGK no longer produces non-resistor spark plugs. If you want to keep running B7ES plugs, then you had better run down to the auto parts store now and buy a box or 2. Soon all that will be available will be BR7ES, with the "R" denoting an internal resistor demanded by automobiles.
thumbsup
Don't hide 'em, Ride 'em !!
RF Whatley
NE Georgia, USA
No ignition coils on magneto bikes.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
What gap on plugs? Too wide a gap with magneto is bad. Thinking .016" is good
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Beach #852962 07/03/21 4:31 pm
This comes as shocking news to me.
1 member likes this: Beach
If there were you might have to change your name to Coilman!
Vintage US bikes with Morse type magnetos have separate coils......Isn't the Lucas armature a coil.....Plug gaps? .018 with the non resistor Iridium... in the past I never had issues with .022 using conventional plugs...
Over the years I have always used 20 thou for plug gap with magneto and 25 thou for coil ignition.
Never had a plug gap problem using those gaps.
Had plenty of other problems but that as they say is another story!
A Magneto Armature is a coil , or 2 coils , which is normally known in AC parlance as a Transformer .
... so if anyone wants to be known as Transformer-Man , i think the name is still open .
Back on topic for a minute..The man who reconditioned the mag says one pick up brush was hanging up. He ran if for an hour with no problems. Last I head he was setting up a elevated temperature test....The mag man is supposed to be one of the best....
But...big changes have occurred, stay tuned to this channel for the latest updates...
This is why you need a magneto armature tester. You can "run" the armature on the bench at varying speeds, look for insulation breakdown, and swap out the capacitor while it's breaking down.
The machine doesn't lie.
RF Whatley
NE Georgia, USA
I bet you know the magneto rebuilder by name and know he has all the equipment...
To put in a, ahem, plug for magnetos, the one for my Ariel sat totally neglected on the shelf for nearly three years, but the bike started on the first kick once the bike was back together. Try that with a battery ignition system.
The double engine racer I built has sat in my rider's pub since It's last race on July 25 2018. it has a onboard lithium iron battery that has not been charged since July 2018...with Pete Suchawreck from this site as a witness, I pressed the starter button , the Harley starter motor turned over two high compression Triumph engines with Pazon Smartfire ignitions with no problem. The engines started so quickly we both jumped back....The bar patrons also were startled, some beer was spilled, lol. I had no idea a lithium battery could hold a charge so long.
But a magneto can still fire some engines after dozens of years...
1 member likes this: NickL
Moderated by  Jon W. Whitley
