Richard Phillips
Richard Phillips
San Luis Obispo, CA
Rohan 82
quinten 79
Edalfa, SDiff, Chopperbabe, Looping, Teager
11,844 Registered Users
4 members (Mark Parker, Andy Higham, triton thrasher, L.A.B.), 20 guests, and 64 robots.
#852525 06/27/21 7:02 pm
Z
Z900 Offline OP
Z
On my B33 1957/58 with a standard 4 spring clutch has the below mainnut (on the left) so with a square on it.
I've ordered 4 diff mainnuts (hexacons) but no one fits.
Any idea to find a hexacon replacement ?
[Linked Image from i.gyazo.com]
Hi Z
It appears that the available nuts do not have the threads fully cut, I have seen this mentioned on the A10 Forum,
I found the same issue on a new nut about 5 years ago so it appears they are still "wrong"
Luckily I have a 5/8 x 20 tap, running it through the nut cured the problem
If you cannot find a tap you could send me the nut and I can sort it (them)
1 member likes this: Z900
Z
Z900 Offline OP
Z
Hi John. the problem is not that the thread isnt fully cut, but i can only bring it up bij 1/2 turn on the shaft. So the thread isnt the right one.
In your pictures the thread on the new nut on the right doesn't look fully cut to me.
Z
Z900 Offline OP
Z
Yes, that were my thoughts also....the thread seems not "sharp" enough ...isnt it ?
