Beach
Beach
West Virginia, United States
#851084 06/08/21 6:47 pm
I have purchased new exhaust pipes for my 73 thunderbolt. Does anyone have any suggestions on coating the inside of the pipe to help keep them from turning blue?
Eastwood a sell a high temperature ceramic coating spray. You have to buy the special nozzle then cut off the original hose and fit a longer one (these are aimed more for the car market with short cast manifolds)
They also sell a pre painting prep spray which is probably my nothing much more than IPA and Acetone but I still bought this anyway. I wasn’t going to risk the product not adhering properly for couple of quid on the prep.
There’s enough in the tin for a few passes, I kept running through until the tin emptied. Letting it dry in between.
If you go this route, do it well away from anything else. You get quite a bit come out of the nozzle, but you need it to, it doesn’t reach quite everywhere so once you’ve given it a pass. Cap the ends off and really swish it around the pipe. If like me you let it run out of one end accidentally it sticks like bird muck on fresh linen (I have a garage door which nice bright silver paint from my accident) I got some off but what dried is impossible to remove without removing the paint off the garage door also.
Hope this helps.
F
F
Russ, following is an excerpt from a post/thread I responded to back in 2018:
Richard, I have done several bikes pipes using this approach. Harley Davidson used to make a solution that was a milky white color, about the consistency of very heavy cream, and also had a sandy, gritty texture. After coating the pipe, I put it in the oven at about 175°, for about 30 minutes, then I coated it again, and again in the oven. The product put about 1/16-1/8" of thick coating similar to ceramic but probably not as durable. Pipes have kept the chrome look for almost 10 years, and I have no complaints as Steve Erickson described with it coming loose. I am sure the cleanliness of the inside of the pipes has a lot to do with this. I applied it on new pipes. Sadly the Harley product is no longer available. But I have also used a product from Kreem, the same people that make the notorious fuel tank sealer kits; it is a blue colored product and is very similar to the stuff I used from Harley, but it didn't seem to work quite as well. Still I have no complaints from using either one. Both products have kept the pipes from bluing.
Fullminator
I haven't had good luck with any pipe coating. I think some pipes are thicker and chroming done correctly or not. Pipes done right stay nicer.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
The stuff Fullminator talks about was called "Dyno" I recall. My problems with it were most likely surface prep related... though I preferred to blame Harley.
I think Eastwood makes a coating, maybe someone has some feedback on it?
...oops, Allan already did post on it, 'scuse me...
As previously mentioned.
Hope this helps.
It isn’t as thick as the Harley stuff mentioned above and I have yet to run the bike with it, but being an Eastwood product I am quite hopeful.
Right on, original pipes were 1.5mm thick, the Armours pipes are about the same thickness and they do stay looking like fresh chrome
For longer. Most after market pipes are 1mm thick and these will turn golden quickly regardless of how lean your mixture Is or how rich it might be.
I have had all of my pipes internal ceramic heat coated. It has to be done before the pipe is used. That is easy on new repop pipes or NOS pipes. I've had it done to used pipes after they have been re-chromed as the plater facility tank stripping process cleans out the interior built-up carbon and rust. The internal heat coating helps reduce the blueing & browning/yellowing of chrome pipes.
The company I used is Northwest Industrial Coatings (NIC) in Oregon. https://www.nicindustries.com/ They developed the heat and slick coating process and powders. They no longer do the coating work, now sticking to manufacturing and selling the powders. For looks they have 1000's of color choices.
When I was building and racing experimental aircraft, they used to use us as experiments for their R&D. The engines I built had both heat and slick coatings on the internals. Slick coatings on the sides of the pistons, and heat coatings on the tops. Any friction surfaces in the engine got the slick coatings, ie cam, crank, pistons, rods, piston pins, gears, valves, valve seats & guides, lifters, pushrod ends, even the bearings. It was like a bearing on a bearing. Very slippery and durable stuff.
They would heat coat the inside of the aircraft headers as well as coat the outside for heat and for looks in order to help reduce the aircraft inside cowl temperatures which were fiberglass as the pipes were, in some cases, within a 1/4" of the cowls. It was a challenge for them as EGT's are hotter on aircraft engines than vehicles, and the heat coatings were initially not holding up. They finally figured it all out.
