Richard Phillips
Richard Phillips
San Luis Obispo, CA
In the 15 years I've owned my 71 Lightning I have never managed to do this. My bike has a custom wiring harness. The battery is also not a stock style. Instead of the posts like stock it has male connections that accept female wire connectors. The colors of the harness do not match the factory ones.
This is the way the bike was purchased. It has a Boyer ignition, Sparx regulator, and a Sparx alternator. I somehow reversed the battery connections. The bike ran OK for 10 miles then quit. It would start after a short rest, then stop after a couple of minutes. After my son-in-law brought his trailer and we got the bike home, I found what I did. I reconnected the battery correctly and checked everything. It starts OK, the lights and horn work as normal. The only thing I noticed was the battery has a little leakage at the top. Only 1 small drop. When running it appears the battery is charging. I checked with a volt meter. Before I take it out again, I want to be assured it will get me home. At 71 years old the thought of pushing it any distance is not good. Any suggestions ?
The battery is probably a little cooked but they are tough old things.
I'd put it on a charger for a night then do a simple load test, like
connecting a lamp to it for an hour or so and see how it fairs.
If it takes a charge and stays there around 12v after testing then it'll be ok.
Just my 2c.
NickL +1
When the battery was connected the wrong way round, I would have expected there to have been a short through the reg/rec and either the fuse to blow (if correct and fitted) or wires to suffer overheating.
Have you found a blown fuse? Or damaged wires between the battery and reg/rec?
I find it difficult to imagine how the Boyer worked under reverse polarity. I can only hope that the fuse blew, isolating the battery, and that the engine started and ran on alternator power alone.
Though this doesn’t explain why it wouldn’t run long term, unless you tried to use lights as well.
Whatever happened, it appears that you may have got away with it, though I’d suggest checking for compromised wires, ensure a correct fuse is fitted in a single wire battery connection (ideally the ground), and clearly label the battery wires!
Can't understand how it managed to run with the battery connected backwards...
The one time I connected a battery the wrong way around (I think both wires were brown from memory) the bike ran ok, but soon as the revs increased the fuse popped and stopped the bike.
"The one time I connected a battery the wrong way around (I think both wires were brown from memory) the bike ran ok, but soon as the revs increased the fuse popped and stopped the bike."
Was that with EI or points Allan?
If you have any electronic components it is hard to understand. I'd love an explanation as to how it would work!
what i would do is some simple maths
charge the battery up to max and give it a few extra hours just to be sur e
somewhere on the battey it wil tell you how many amp/hours it has fully charged
get a headlight bulb with know wattage and hook it up to battery and time how long it takes to go flat
eg a 50 watt lamp running on 12 volts of about 4 amps ( W/V = Amps)
so divide the amps of the bulb into the amphours of the battery
eg a 6 amphour battery should drive a 4 amp bulb 1.5 hours as i said not exact but its a pretty good test
this is a bit of a guess method because when the voltage drops it wont be the same amps
but if it goes flat in 5 minutes it will tell you
as for damage to all the EI stuff that is beyond my pay grade
Simple maths would suggest with the battery the wrong way round the current through the rectifier (regulator) would be enormous and should blow the fuse (if fitted).
Failing that, it will blow the reg/rec and damage associated wiring, possibly causing a fire.
By the time you’ve done the simple math, the system is toast. I’d suggest it is better to anticipate such situations.
Calculating battery discharge is not that simple .
a faster discharge ... results in less return.
it you try are draw 4 amps out of a 12 amp battery it will release
about 9 amps in 2.75 hours and be dead .
... 3 amps are lost to heat in the battery , the heat lost is caused by the speed of the chemical reaction .
battery companies use slower discharge rates to boost the label rating .
( the label rating is real , but only if slowly discharged over 20 hours )
image is for a typical 12 amp battery ... 0.6 amps x 20hrs = 12amps
The amp rating on the side of the battery is based on a 20-hour discharge .
label amps / 20
[Linked Image from i.stack.imgur.com]
i would use a 2 amp draw to test a motorcycle battery ... drawn down to 12 volts
... 2 amps is the brake light filament side of a dual filament bulb , typically about 27 Watts .
2 amps is about what the Boyer /Pazon analog ignition uses .
So using a 2 Amp draw to 12 volts will tell you about 1/2 as long the battery will feed the ignition
... you can drop down to 10 volts to get an exact time ... been a full drawdown test is harder on the battery .
In either case the battery should be recharged immediately .
a britbike doesn't need that much of a battery ... it's more of a limp home feature should the
Alternator/V.regulator fail .
its kind of nice to know just how far your bike will run on the battery and not guess .
or carry a cell phone.
Suggest that you buy a battery load tester.
They give you a firm indication of whether the battery has been well and truly b******d.
I bought mine several years ago for about $30 and it has proved to be a very worthwhile investment.
I agree. For those who don't know, a load tester is a voltmeter and a low-ohm resistor. The resistor puts a big load on the battery, and the voltmeter shows to what extent the battery is drawn down. A load test can be accomplished with a light bulb, but a load tester will tell you in 10-15 seconds what takes many minutes to determine with a light bulb. And the load tester meter is marked with red, yellow, and green bands as well as volts (green = good, yellow = weak, red = replace).
Good point/question. It was on points at that time.
I do have a load tester and will try it today. I checked the harness and found nothing melted or charred. What's the best way to check to see if the regulator is toast ? I charged the battery with the battery Tender and it held voltage overnight. The battery is not very expensive so I might just replace it.
Checked the battery today with the load tester. Checked out fine. Checked the charging, seems to be OK. All wiring intact. Thanks to all who offered help. Great forum.
Suggestion: Buy your son in law dinner and in return, have him follow you with his trailer on your first ride. Real world advice.
Great idea. I live by a large parking lot. Will try test rides there. Only a couple hundred feet to push home if necessary. Thanks again.
