BeezaBryan
BeezaBryan
Derbyshire UK
Allan G 80
quinten 52
Cyborg 19
11,757 Registered Users
8 members (Hugh Jörgen, GrandPaul, koan58, Magnetoman, L.A.B., Mikeyd, TR7RVMan, bones_bir), 32 guests, and 79 robots.
#849572 05/21/21 3:07 pm
OP Online Content
1970 Commando
Am toying with the idea of Pazon EI.
From what I have read PVL 6V or Dyna Coil to match the EI seems to be the way to go.
Anyone have any provisos about either?
1970 T120R - 'Anton'
1970 Commando - 'Bruno'
1967 T120R - 'Caesar'
1968 Lightning - 'Dora'
I've been running 6v PVL on my T140 for over 20 years with no issues
OP Online Content
Thanks shel.
That's with EI?
Seems EI has it's own optimal associated bits.
First with a Boyer now with a Pazon
OP Online Content
I might as well go to the well one more time. smile
Podtronics?
Originally Posted by Hugh Jörgen
1970 Commando
PVL 6V or Dyna Coil
... or Tri-Spark?
Podtronics?
confused That link goes to a message from Fleabay that it can't find "Podtronic" ...
Nevertheless, I'm confused what that has to do with coils for an EI - Podtronics make reg./rec.?
OP Online Content
1970 Commando
PVL 6V or Dyna Coil
... or Tri-Spark?
Podtronics?
Thanks Stuart.
... or Tri-Spark?
Had not considered Tri-Spark coils as they don't seem to have many mentions and I make an assumption (I know) that they are matched in some way to the Tri-Spark ignition. Or is it just a label?
I am finding pukka PVL 6V's pretty thin on the ground.
The 'go to the well' comment was intended for shel as he had been so kind as to provide a couple earlier answers.
I suspect 'Podtronics' is another of the link re-write words that messes with our linked images.
Again it was aimed at shel just to see if he also used a Podtronics unit in conjunction with his Pazon/PVL setup.
Pazon EI.
confused Curious use of "match"?
Pazon, Tri-Spark, any EI for these old heaps are just a fancy on/off switch to replace points and auto-advance unit. Apart from things like Boyer-Bransden MicroPower and similar Pazon Smart-Fire, they all basically work with total coil primary resistance between 3 Ohms and 4-ish Ohms.
Risking telling you something you know already, "primary resistance" is between the spade/stud terminals on a Lucas or pattern coil, between the ends of the two thin wires on some other coils (e.g. a coil with two HT leads).
Between 3 and 4 Ohms is a '12V' coil.
If you want a separate coil for each cylinder, divide the '12V'- and therefore the primary resistance - by the number of cylinders, use individual coils of that divided 'Voltage'/resistance connected 'in series' - i.e. in your case, two '6V' coils between the Pazon "Ignition Module" Black wire and battery +ve.
When components are connected 'in series', their individual resistances are cumulative. A '6V' coil should have a primary resistance between 1.5 Ohms and 2-ish Ohms, so two '6V' coils add up to the same as one '12V' coil.
Reason I've written "4-ish" and "2-ish" is because particularly PVL's have a slightly higher primary resistance than 'original Lucas' and Tri-Spark coils, but PVL still work fine.
Apart from primary resistance, there isn't any other "match" between particular coils and EI makes.
Btw, be aware at least some current 'Wassell Lucas' coils have bizarre primary resistances - 5 Ohms? - totally unsuitable connected in series to an EI.
Reg./rec. make shouldn't have any bearing on EI make - two different electrical circuits.
OP Online Content
Thanks Stuart.
Crew Chief
Crew Chief
ET coil?
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Hi Dave,
ET coil?
Uh-uh, look like normal DC coils, not original 2ET or 3ET.
Original saved link advertising them as "suitable for both 6V and 12V" doesn't work. frown Google turns up suppliers advertising Wassell Lucas '12V' with 5-Ohm primary resistance - e.g. https://www.oldtimerbedarf.de/LUCAS-MA12-Motorrad-Zuendspule-12V-5-Ohm-Schraubanschluesse, https://www.feked.com/genuine-lucas-12v-ignition-coil-12-volt-lu47276.html; the latter also advertises '6V' with 2.5-Ohm primary.
Moderated by  Dave Comeau
