Topics76,535
Posts776,186
Members12,210
Most Online204 Jul 10th, 2022
Posts: 104 Likes: 3
Posts: 104 Likes: 3 |
Are the frame and engine numbers the same on a 1957 Cub. It is a swingarm frame. The number on the one I looking to buy are: Frame T2625 Engine T20 26858
Thanks Al 2016 Tiger 800 XRx 1969 T100R (in Restoration) 1957 T20 (needs restored)
Posts: 121 Likes: 6
Posts: 121 Likes: 6 |
They are always the same no matter what year. T2625 is a 1954 and T26858 is a 1957. Most title states go be the frame number.
rightshifter
1967 T20M 1958 T20C 1960 T20S 1960 T20SS 1961 T20 1965 T20SC
1965 T20 1969 T120R 1970 T120R 1957 TR5 1967 T120R
Al Navecky Jr |
Posts: 104 Likes: 3
They are always the same no matter what year. T2625 is a 1954 and T26858 is a 1957. Most title states go be the frame number. Could a 54 plunger be converted to a swingarm frame.
Posts: 3,708 Likes: 67
Posts: 3,708 Likes: 67 |
The frame and engine number should match. That may be a frame part number, are you have the stamped frame number?
Posts: 104 Likes: 3
Bill B... Yes that number is stamped.
Posts: 831 Likes: 16
Posts: 831 Likes: 16 |
26276 - 35846 are the 1957 Cub numbers. I am thinking that your frame number is actually matching the engine, but perhaps its hard to read, as they can be. The headstock number is usually F4221 which can be stamped or more usually cast in.
1958 5TA / T100 1965 T120R 1970 TR6 1970 TR6C
Posts: 1,420 Likes: 36
Posts: 1,420 Likes: 36 |
It is possible to convert to a swingarm, the rear section bolts on. Not sure of the exact fit, but nothing a good welder and some oxy heat couldn't fix if it was needed. But you would need to show us clear photo's of the frame and engine number...to see if we think they are genuine factory stamped?
Posts: 104 Likes: 3
Thanks guys for your help. I pick up the Cub Sunday. So I will have more info and photos.
Posts: 2,095 Likes: 34
Posts: 2,095 Likes: 34 |
I'm not sure that a plunger frame is bolted? Without going to my garage, I am pretty sure it's welded/ brazed?
A plunger frame is worth a lot more than a swing arm one
Al Navecky Jr |
I messed that one up, result of running a high temp and some dreaded lurgy...sorry. Getting off before I do it again
Posts: 104 Likes: 3
My bad after getting it home and cleaning the frame and getting a better look the numbers are the same.
Thanks for all your help probably need more help when I start the restoration. Got to get my 69 T100R done first.
Posts: 671 Likes: 73
Posts: 671 Likes: 73 |
Result! It will make a lovely little 'bike
Al Navecky Jr |
