MikeG
MikeG
New Hampshier USA
quinten 91
Rohan 65
quinten 13
makrph, vanGinneke, Gearhard, yornocT120R, robert wilby
11,840 Registered Users
2 members (Semper Gumby, Gordon Gray), 26 guests, and 95 robots.
#848250 05/06/21 7:30 pm
I bought this weird thing on eBay. It has a Matchless 500cc twin, the front end has Triumph labeled trees, and the transmission looks like a BSA A10 transmission. However, I have no idea what the frame is - not even sure it's British. Does anyone have any ideas? Pretty sure it's not Matchless, but the 1951 Matchless has a similar hole in the downtube like a 1951 Matchless G9.
Any ideas what it is?
[img]https://postimg.cc/BLRNj3DX[/img]
[img]https://postimg.cc/bsMhTSh5[/img]
Front half of the frame is late Triumph rigid.
Chris
Thanks Chris. Do you know where I can look for a serial number? I've looked at the neck, all tubes and can't find anything. There is this:
[img]https://postimg.cc/2b7Y7CdX[/img]
I can't really tell if this is a serial number. Does it look like the right place and format for a Triumph serial number? I note that this is a frame that is designed for the engine to be a stressed member, but not this particular engine (hence the use of adapter plates for mounting).
I'm not worried about the back part - I think it's a custom made part.
Now that you mention Triumph, I found this on eBay and can see many similarities:
Triumph Frame on eBay
It's just that weird hole in the downtube that throws me off.
Frame number would be on the other side of what you’ve shown, left side of the frame, behind the headstock, stamped in and not raised/cast in place.
That’s not intended to use the engine as a stressed member. Someone has created engine mounts that accomplish that. The original rear section has lower frame members that begin at the bottom of the front down tube and extend back to the rear axle.
Chris
1 member likes this: Gary Colwill
That hole is for the air filter connector hose to pass through. Only used in 53 and I believe 52. Others know more than me.
Chris
Very nice info - thanks. So, did these even have serial numbers on them in 1952-53? I know early Harley's just went by the engine number and the frame had no number. Maybe that's the case here and I'm searching for a number in vain. :-)
Harleys were a law unto themselves in that era.
Everyone else had frame numbers ...
Has it been painted over, or ground off even ?
Bingo: 1952 Triumph Thunderbird 6T
Image #10 shows the hole very clearly.
Can't really tell where that serial number is located though. I'll search some more, now that I have a clue.
Thanks much.
Care to weigh in on the wheels?
[img]https://postimg.cc/QVsKGbtc[/img]
[img]https://postimg.cc/VdkS5kX6[/img]
Maybe. I don't mind wire wheeling off a little paint if I know where to start. Trying to figure that out now. This won't be the first bike I've gotten with a painted over serial number :-)
Look japanese. Even the 1st axle looks japanese.
If there is enough left of the rim, can you read the makers name stamped into it.
That 1st one could be suzuki TLS, with one of the cams omitted ?!?
(Maybe there are no shoes inside ?!)
Good Luck ! We hope you bought it for the engine ...
Hah - that's exactly why I bought it. And it turns and has compression - I just checked. Very happy about that. Maybe I'll just junk the rest. Maybe someone will find value in the transmission.
In fact, if anyone here sees any value in the frame, transmission or other parts, let me know.
Hi Gary,
What letters/numbers are stamped on top of the BSA gearbox?
Depending on those the gearbox could be worth a decent amount
STD:
[img]https://postimg.cc/S2TCZYhn[/img]
Sounds bad...
Everything has a value. Even japanese hubs - if you can figure out what make/model/year they are.
I was once given an M20 engine WELDED into a Matchless frame. (that saves on bolts !)
I reckon that contributed to about 10 bikes restorations ...
STD:
Sounds bad...
STD (STandarD) was the most common swing-arm pre-unit BSA gearbox. They don't bring the high prices of the more exotic competition gearboxes, but are still worth a few dollars. The 6-spring clutch can be made to work acceptably, so that probably adds a bit to the value of the gearbox..
I'm wondering how well this BSA gearbox matches up to this Matchless engine. Any thoughts on that? if they work well together, maybe I'll keep the gearbox.
Found it:
[img]https://postimg.cc/CZh5x9mj[/img]
19159NA
1952 model year.
1971 BSA A65 650 - Project
Oooo, a grease fitting for the steering bearings. I like it!
Only works if the frame tubes are blanked off or all they do is fill the frame with grease which makes the bike quite heavy .
Even if the frame tubes are blanked filling up the headstock tube with grease can have a detrimental effect on handling. It will be like a steering damper you can't release
GM500 sprint bike "Deofol"
Only if the ends are sealed pressure tight
I fill mower blade spindles with grease every day
makes almost no differenc to the freedo of their spin.
What the grease does is keep dirt debis & water out thus extending the life of correctly fitted bearings.
Moderated by  Jon W. Whitley
