Cyborg 69
Cyborg 19
Sinner66, DucatiPete, mk31755, MAM, Jonez69
11,977 Registered Users
7 members (Magnetoman, Gordo in Comox, Dr. Z, desco, Rohan, ricochetrider, Chris Johnson), 27 guests, and 22 robots.
Topics75,254
Posts758,029
Members11,977
#847690 05/01/21 5:37 pm
Here are the printed parts for the B50 version of the KTM clutch
The chainwheel will have to be steel because of the closeness of the teeth to the diameter of the plates. Probably use 1045 or 1144 Stressproof which can be hardened to 52 Rc.
The chainwheel runs on a needle bearing, the drum runs on a bushing. When the clutch is lifted the drum is held against the hub by the spring force so the only load on the bushing is from the clearance in the needle bearing.
All the other parts are KTM.
Is this something you are planning to put into some sort of production and sell?
Peter
3000 BSA part numbers with inventory in stock just for the unit singles!
I will need one from mine and two others are interested so I could make a short run. No idea what the market would be.
I'll contact you off line to talk further.
Peter
