Tridentman
Tridentman
Rohan 82
quinten 79
Edalfa, SDiff, Chopperbabe, Looping, Teager
11,844 Registered Users
4 members (GJVGC, Servodyne, kommando, NotRetroOldFart), 23 guests, and 58 robots.
Page 2 of 2 1 2
Yes, I guess now days it is, but it sure is a nice smelling band aid. Or maybe it is a safety net?
But these bikes with a C/R higher than 9 to 1 were meant for 100 octane and race gas is a solution for shorter rides. I use it in all my dual sport BSA's and have not had any piston seizure or holing problems in over 15 years.
It is simpler and more accessible to many of us than re-designing these old engines with dual plugs and quench areas.
Triumphs on eBay
BAinLA Offline OP
Ok, just re-set the points. The gaps were off and the right side was maybe 2° past the fully advanced mark. I set them both to about (just eye-balling it) 2° retarded until I get this sorted. No test drive yet.
New question for you guys that haven't been away for 35 years; What is this part? It was in the parts box that came from the original owner in the early 90s. Everything else in there had a place on the bike except this. It seems like a tank mount from an earlier model? It looks well used (and well rusted).
1972 TR6RV
BAinLA Offline OP
Thanks for the tip Stuart Kirk. I actually don't have a pinging problem. The points came loose on the 2 freeway and I pulled off and "fixed" them temporarily and finished my ride. I'm going to keep my ears open and make sure there is no ping in the future, a little difficult with an open face 1/2 shell helmet but that's another issue. Brian
1972 TR6RV
Originally Posted by BAinLA
...... I'm going to keep my ears open and make sure there is no ping in the future ....
Yes. As the weather heats up and your riding gets more spirited, you will probably get some pinging. So keep that race gas in mind. It's expensive but our old bikes love it. I like the peace of mind myself.
A mounting clamp plate for an accessory sissy bar or a rack? Maybe for a tool pouch?
BAinLA Offline OP
Originally Posted by TR7RVMan
What ever happens don't let bike ping at all....You let it ping at all, it will hole a piston very quickly
Running race gas helps a lot BA. The pinging vanishes! You can buy it at the pump from the Alliance station on Chesebro Rd just off the 101. It's 103 unleaded. I use it all the time and fill a 5 gallon can whenever I am by there.
Thanks Stuart Kirk, I may take a trip out there for 10 gal. if they still have it. Edit: Just checked , they have it. Will cost me $97.50 for 10 Gallons (plus $6 in gas for transport. Taking another look at just retarding the spark and de-carbonizing. -BA
Originally Posted by desco
Race gas is a Band-Aid not a cure.
desco, I agree. Until I get the carbon out and the mixture better, I think I will try this during the summer heat. Had to stop and knock the points plate back a couple degrees last ride but it still tended to ping at the usual rpm/throttle opening.
If that bike idles with the screw all the way in there is something wrong with it.
http://www.jba.bc.ca/Bushmans%20Carb%20Tuning.html
Got that sorted. Now more like 1 3/4 turns out.
1972 TR6RV
Page 2 of 2 1 2
