GrandPaul
GrandPaul
Leander (Central) Texas, USA
64 a65 motor. Bob newby belt drive. There two widths of spacers used behind the clutch drive sprocket (pulley now) on the crankshaft over the years. Not sure which one I should use for the belt drive setup. Supplied Installation instructions sucks..
In before the long winded discussions...., the pulleys need to be lined up exactly especially if they have side rails...Use a straight edge and select the appropriate spacer. It's that easy
1 member likes this: JER.Hill
Oh duh,
don't have the gearbox in -so couldn't set the basket up -so couldn't line up the pulley and basket -so couldn't pick spacer
I was putting the cart before the horse as they say...
You have the spacer which passes through the oil seal, that should be the same for all years.
Then fit the pulley,
Then fit the supplied spacer. I’ve had 4 of these pulleys and they all seem to be somewhat different in the internal width so ensure that you use the supplied spacer at this point. Then insert the woodruff key (usually this has a recess in the spacer to help the key fit in. Then fit the alternator rotor.
Dont forget to use the supplied studs and spacers for the alternator stator. (Check first what thread form studs you have received. You might need different ones if using a pre 69’ motor) I think they come with unf/UNC studs.
Also check for alternator gap when finished.
W
W
The spacer comes in 3 sizes I thought, but I may be getting confused with Layshaft spacers. Definitely more than one size though.
Gavin
It does not need to line up exactly like the chain does. So long as the belt rides near the middle of clutch wheel it is ok.
I think your using the 40mm belt Tom?,
The baskets are all the same but the 30mm belt (for road bikes) sits closer to the back of the basket, you probably have about 1-2mm of basket that you can see at the back of the belt, and a whole lot more at the front side of that.
I beleive I am on about item 5 on the diagram, I don't beleive these ever came in more than one size.
I use the 30 on NA bike and 40 on turbo.
Thats good to know, do you have to front pully of the same width to match? I have the 40mm kit for the race bike (for when it eventually gets done) but only used the 30mm on my road going bike.
Yes, the 40 uses a wider pulley.
W
W
"I beleive I am on about item 5 on the diagram, I don't beleive these ever came in more than one size."
I was referring to the same spacer in the diagram too, and they definitely come in at least 2 sizes. I know, I have them. I'm sure I've seen some NOS ones on Fleabag.
Gavin
Well I won’t argue, if there is a thicker or thinner spacer though it must match up with a different crankshaft sprocket. I knew there were different ones one these but this was for the timing disc for the ET models. That or the offset on the early clutch setups is different to the later 3 spring type?
The early motors used 2 different (select on assembly) spacers.
Later models used shims and one thickness spacer.
