TJD
TJD
Devonport Tasmania
do you have a high beam or dip beam warning lamp on the headlight shell? i'm questioning my 66 spitfire - has none. one owner of a lighting states he bought his 66 from the original owner w/ 500 miles - original and hasn't changed a thing, and he also does not have any such lamp. my 66 instruction Manual shows a lamp and also the wiring diagram, however the parts Manual shows none. so, 66 owners only - do you have a high or dip warning lamp on your headlight shell? thanks....
My 1966 Lightning had no warning lamps at all in the original headlight. Just a light switch and ammeter as shown in the 1966 parts book.
I have fitted my bike with a later headlamp shell with the later toggle switch, ammeter and warning lamps for oil pressure and main beam.
As I don’t have an oil pressure switch on the engine I am using that warning lamp for ‘lights on’ function, although at some point on the future I would like an oil warning lamp and preferably an oil pressure gauge.
Kev E
Ola Offline
Like this?
[Linked Image from oseose.webs.com]
(Doug Hele, 1919 - 2001)
my 66 instruction manual shows a lamp and also the wiring diagram, however the parts manual shows none.
If it's the same as '66 Triumphs, early don't have any idiot lamps, middle have one, late have two ...
Red idiot lamp wasn't used for oil pressure warning 'til '69-on; before that, the bulbholder just had a White wire (so energised when the ignition switch is turned on) and a Red wire, so the idiot lamp was just an 'ignition on' warning.
When two idiot lamps were fitted, it depended which colours a given production-line worker pushed the bulbs into - a bike could have red 'ignition on' and green 'high beam' ... or the other way 'round ...
1 member likes this: Kevin E
I have wired my 68 like this, it should have main beam warning only but the shell had two holes. Also I used to leave the ignition on by mistake and come back to a flat battery.
The only issue I have now is getting "helpfull-types" come up to me whilst Im sat on the bike and ready to go and squark "arr' your oil pressure light is on mate" then spend 10 minutes trying to explain to people that I've wired it as an ignition warning as it doesn't have a oil pressure switch.... But at least I don't have a flat battery now.
