gunner
gunner
Farnham, Surrey, UK
#844844 04/01/21 7:13 pm
Jcsus Offline OP
Novice poster
Novice poster
Last summer I acquired a ‘68 A65 bobber. It came with a Joe Hunt magneto. Rebuilt the whole magneto. Bench tested the mag with my impact gun and had great spark. Got all my TDC settings and mounted the mag, but no spark. Come to find out when I kick, the cam isn’t turning. It turns if I crank the alternator side with a ratchet. Question is, before I open it up, what could most likely be the culprit? I’m a moderate hobbyist, and I’m just wondering what I’m diving in to. Thanks again!
It sounds like the kickstart isn't turning the engine at all. While you can see the alternator nut, see if this is the case. Detach or totally slacken the clutch cable for this test.
If so, then its likely to be a problem with or behind the clutch. The entire clutch maybe just slipping on the mainshaft.
If its not already off, take the primary case off. It sounds like this will be necessary for whatever treatment is required. Who knows, you may even find there's no primary chain in there!
Jcsus Offline OP
Novice poster
Novice poster
Luckily I have a belt primary with a Norton Commando clutch basket. I’m learning the previous owner rigged a lot of stuff up just for the sale of the bike. I don’t think it’s a clutch problem though. If I put the bike in any gear and try to kick it, the bike pushes forward. In passing, I learned one of my gear box oil seals is bad. When I put the bike on the stand, the gearbox oil leaks out the primary side. So maybe I’ll get to replace that when I open up the gear side. I just wasn’t sure if it was a sheared pinion or a problem with the layshaft (as I had previously read about). Thanks again for the reply!
" I don’t think it’s a clutch problem though. If I put the bike in any gear and try to kick it, the bike pushes forward."
Even if you take the clutch off completely it will still do this.
Jcsus Offline OP
Novice poster
Novice poster
Thanks for the advice. That’s something I didn’t know. I’ll report back with findings. In case someone else gets into this predicament.
Right, the kickstarter turns the tranny mainshaft. If the clutch is engaged, the tranny mainshaft turns the primary drive, which turns the crankshaft.
The idler pinion (on which the dwell cam is mounted) is gear-driven off the crankshaft, so it must turn if the crankshaft turns.
If you're feeling some resistance in the kicker, then it's likely that all the parts are there and the clutch is slipping. It could be as simple as an adjustment. It's been a long time since I've looked at a Norton clutch, but I assume it has a pushrod clearance adjuster in the center of the pressure plate. Go there and back off that adjuster to where you know the pushrod is not in contact with the pressure plate, and see if the clutch still slips. If it still slips, then it's time to open the primary and see what's going on.
