Bikeosaurus
Bikeosaurus
Canberra, Australia
#844596 03/30/21 3:33 pm
F
Novice poster
Novice poster
F
I own a 1968 A65 Lightning and a 1968 B44. I have limited knowledge of these bikes but have worked on them to some extent. I have various books etc that explain how to work on them but they leave a lot to be desired if you are at my experience level. I have replaced the clutch plates on the B44 and have question about the difference between the clutch/kick start differences between the B44 and the A65. The A65 will allow the engine to be kick started with the clutch disengaged, even if in gear. The B44 will not allow the engine to kick start with the clutch disengaged. In other words the B44 will only kick start the engine if clutch is engaged (therefore must be in neutral). The A65 does not care if clutch is engaged or disengaged. Is this the normal operation of these bikes or is something wrong with one of them.
There is something wrong with your A65. Both should only be able to be kicked over with the clutch lever untouched (clutch plates forced together by the clutch springs and so clutch engaged) and in neutral if the rear wheel is touching the floor.
F
Novice poster
Novice poster
F
Thank you. Any idea why this is happening, as clutch seems to be working otherwise?
You clutch must be stuck.
The kicker turns a gear within the transmission. With a working clutch, the transmission is only connected to the engine _if_ the clutch is engaged. Disengage the clutch and you separate the connection between engine and transmission.
On other bikes, the kicker bypasses the transmission and turns the clutch basket which is always connected to the engine. In that case, it doesn't matter whether the clutch is in or out; the kicker will always turn the engine.
What do you mean by "working otherwise"? I would think, if the clutch were stuck, which it appears to be, you would get a terrible slam and stall the engine when you put the bike in gear.
You may be able to free the clutch by putting the tranny in gear (I'd suggest 2nd), pulling in the clutch lever, and violently rocking the bike forward and back. If that doesn't succeed in freeing the clutch, you'll have to take it apart.
F
Novice poster
Novice poster
F
My bad. Clutch is stuck. I had not started in a while and assumed clutch was OK. Thanks for you all helping me. I will try and be a little more deliberate before jumping to conclusion next time.
