Topics76,281
Posts772,286
Members12,154
Most Online151 May 8th, 2022
Posts: 194 Likes: 6
Posts: 194 Likes: 6 |
I accidentally bought a whole bunch of NGK BR8ES thinking they were BP8ES. What’s the difference between the, can I still use these?
Posts: 14,476 Likes: 335
Posts: 14,476 Likes: 335 |
The BR8ES are 5k ohm resistor plugs, the BP8ES plugs are not. Depending on what kind of ignition you have, they may or may not be happy in there....
"Never stand and take a charge. Charge them too!"
Danam |
Posts: 1,926 Likes: 271
Posts: 1,926 Likes: 271 |
I accidentally bought a whole bunch of NGK BR8ES thinking they were BP8ES. What’s the difference between the, can I still use these? My understanding is that the initial BR code indicates a plug with a resistor built in so you probably dont want to use plug caps which already have resistance built in or the spark will be weakened. The BP prefix suggests a projecting insulator type which is used to get the spark deeper into the cylinder. So using a BR plug may work but the spark wont be as far in the cylinder. Have a look at the chart Here for an explanation of the plug numbering.
Danam |
Posts: 8,677 Likes: 248
Posts: 8,677 Likes: 248 |
Considering our bikes never came with a projected tip you’ve probably done the better thing without realising it. The resistor in the plug won’t cause an issue with ei or points, just try to ensure your caps don’t have resistors in them also.
Danam |
Posts: 1,510 Likes: 50
Parts Dealer
Parts Dealer
Posts: 1,510 Likes: 50 |
I could be wrong but I think the BP8ES have been discontinued?
Posts: 92 Likes: 11
Posts: 92 Likes: 11 |
Short answer is yes. The R stands for built in resistor. Some high tech ei systems require resistors but not if you have the run of the mill Boyer or Pazon. Seems like NGK is phasing out non-resistor plugs. For what it's worth I've used both types in the same bike with Pazon Surefire ignition(doesn't require resistors) and non resistor caps and can't tell any difference. The P stands for projected tip. The tip extends further into the combustion chambers. Don't use them in a BSA but they are specified in Norton Commandos.
Posts: 3,464 Likes: 174
Posts: 3,464 Likes: 174 |
NGK has discontinued non resistor plugs. To make it worse, I believe the r plugs have non removable caps so they won't fit the plug caps on half of my bikes Luckily my local napa told me when this was happening so I was able to order all the plugs in the midwest in the sizes i need.
Rich "It's not always about going fast. Sometimes it's nice to slow down" (Wendy E.2016)
69 bonney 72 commando 75 commando a ducati Another couple triumphs and no Honda? but another triumph
Posts: 877 Likes: 10
Posts: 877 Likes: 10 |
NGK has discontinued non resistor plugs. To make it worse, I believe the r plugs have non removable caps so they won't fit the plug caps on half of my bikes .. Luckily my local napa told me when this was happening so I was able to order all the plugs in the midwest in the sizes i need. I've actually had to turn the non removal caps down and install grooves using my lathe and a tool post grinder to get the plug I wanted for use with coil over plug caps...not for a British bike but it is possible if the need arises. Of course, I ruined one plug trying to remove the non removable cap and then another by trying to machine the cap before I went to the grinder...live and learn...Mark R.
Posts: 5,231 Likes: 195
Posts: 5,231 Likes: 195 |
Interesting Non Resistor plugs are still available down here. My mower suppliers still list BP 5's , 6's , 7's & 8's Just for the heck of it I added a box to the order I put in yesterday and it showed them to be in stock. So was it really NGK stopping supply or just Napa deciding not to stock them ?
Bike Beesa Trevor
Its NGK. I know people here that ordered standard plugs shown in stock and got the resistor plugs.
Posts: 7,764 Likes: 267
Posts: 7,764 Likes: 267 |
Something wrong with using Champion N3?
chainreaction |
Posts: 10,470 Likes: 41
Posts: 10,470 Likes: 41 |
Hi Trevor, Non Resistor plugs are still available down here. So was it really NGK stopping supply Here too.  Increasing majority of vehicles needing OE HT resistance to avoid screwing up various electronics, maybe a US NGK bean-counter calculated the cost of warehousing slower-turnover non-resistor plugs was costing 'em too much? Regards,
Posts: 6,392 Likes: 278
Posts: 6,392 Likes: 278 |
Resistor plugs were first marketed in the US around 1950. I believe by 1970 all US vehicles with perhaps the exception of heavy trucks were using resistor plugs as original equipment... Yes, it's either a stocking issue or a violation of some obscure emissons law. Some new n/a two cylinder street bike engines are making near 200 hp per liter out the factory door most likely with supressed wires and plugs...The ignition system in an old Brit bike firing a fat mixture with far less cylinder pressure has an easier job... An ignition in good good condition should have no issue with resistor plugs...
Posts: 194 Likes: 6
I’ve used the NGK BP8ES for years! What’s the best non resistor replacement for them?
Posts: 139 Likes: 12
Posts: 139 Likes: 12 |
Something wrong with using Champion N3? Champion N3's work for me. SteveG
Posts: 177 Likes: 5
Posts: 177 Likes: 5 |
Nothing wrong with NGK BP8ES or Champions N3, N4's We all have our sentimental favorite. For me my go-to plug has always been: Nippon Denso W24ES-U. What's the "-U" all about you might ask? Why that's the patented ND "U" channel in the negative electrode that provides for a "fatter, more all-inclusive " spark to ensure total ignition of those pesky fuel vapors present in the combustion area...an ND exclusive to provide that racer's edge over the competition....!
I only tried the ND 'hot U' plugs once, when the shop put some in my Trident during a tuneup. Maybe he got the wrong heat range, but it didn't run right until I put in some N3s. The A65 likes NGK, the Triumphs prefer Champions. Of course, my old VWs liked only Bosch plugs. The BMW doesn't seem to care, so I put NGKs in it. The K uses both resistor plugs and resistor wires. I'm not gonna confuse that computer.
